-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Capture settings for canon 30f? (https://www.dvinfo.net/forum/final-cut-suite/120187-capture-settings-canon-30f.html)
Martin Kornfeld April 24th, 2008 10:06 AM
I'll be using FCP 6.0.3. Have'nt had a chance to check the edit system out yet. Have Canon XHA1 and would like to shoot 30f HDV footage. Would like to go to ProRes. I'm under impression I can now capture through firewire to ProRes.
Is there now a capture setting for capturing 30f HDV to ProRes?
If not, what would be proper capture settings for 30f HDV capture?
Mike Flynn April 24th, 2008 11:39 AM
As far as I know you use the same settings for 30f that you would for 60i
Martin Kornfeld April 24th, 2008 11:47 AM
so the capture setting would read "prores hdv 60i" or "hdv 60i" but not "prores or hdv 30p"?
