LiveType presets with HDV 1440x1080
1 Attachment(s)
Just wondering what the correct preset values are in LiveType's "Project Properties" pop-up menu when working with HDV footage from my A1.
As there is no applicable preset (Livetypes presets don't update with any FCP 5.1.2 + updates): 1) Should I set the project's resolution to 1920x1080 - or should I set it to 1440x1080 and set the pixel aspect ratio to 1.33? 2) If outputting to interlaced DVD should I select field dominance "odd" or "even"? Presets Screengrab below... |
mike i think your right (though hdv has a 1.33 aspect pixel ratio) - after closer inspection, the other preset HDV settings (60i/50i) had res of 1440x1080 with pixel aspect of 1.33 so I'm assuming this must be the correct preset for 24p also.
Naturally, you would want framerates to match as well, but framerates do not impact upon resolution or vice-versa. |
| All times are GMT -6. The time now is 11:59 PM. |
