-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Best Sequence settings to work with HDV on FCP6 (https://www.dvinfo.net/forum/final-cut-suite/114281-best-sequence-settings-work-hdv-fcp6.html)
Marcelo Costa February 8th, 2008 04:58 AM
I'm a wedding videographer, I just got FCP6 and I have some doubts regarding Sequence Settings to work with HDV, if possible, could someone please help me?
I have a MacBook Pro, Intel Core 2 Duo 2.33 ghz and 2 GB Ram...
I started my FCP6 and selected Easy Setup as HDV-1080i60 FireWire Basic
1-) On Sequence Settings, General Tab, I left it as the easy setup set for me (Compressor HDV 1080i60, quality 100%, field UPPER, etc...).
2-) On Video Processing tab which options should I select?
a) Render in 8 bit YUV or Render all YUV material in High Precision YUV ?
b) Motion Filter Quality as Normal or Best ?
c) In Process Maximum White should I selected White or Super White ?
3-) On Render Control tab:
a) I set codec to Apple ProRes 422.
b) in Master Templates and Motion Projects, should I set Quality to NORMAL or BEST ?
c) in Master Templates and Motion Projects, should I check the box "Always Use Best Quality When Rendering Movies" ?
thanks ererybody for your attention.
Regards
Marcelo
