-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Graphic Quality FCP6 (https://www.dvinfo.net/forum/final-cut-suite/113871-graphic-quality-fcp6.html)
Scott Aubuchon February 3rd, 2008 04:49 PM
I'm really struggling here... Why do my graphics I bring in from Photoshop look like crap?
http://www.sacreativeservices.com/fo...third_crap.png
Now, before you tell me to check the obvious, I will give you some background:
Footage = HDV
Timeline = Apple ProRes 422
RT settings = High
Motion Filter quality = Best
My footage looks great, my motion graphics look awesome, its just when I dump a static image into the time line, it looks all wonky. This is not a canvas issue, because its still there when I render.
I am not using low quality JPGs either, only TIFF/TARGA or PSD.
When I create the graphics in Photoshop, I use 1440x1080 with a PAR of 1.333...
What am I doing wrong?
FYI... I just tried motion file (which the graphic looked perfect in motion) and then dropped the motion file in the FCP timeline and it still looked as bad as above!
Andrew Kimery February 3rd, 2008 07:19 PM
Since you are using a ProRes timeline, which is full raster, have you tried making the gfx 1920x1080 square pixels? Also, red is a problematic color for video so maybe de-saturating the red a bit or using a different color might yield better results.
-A
Scott Aubuchon February 3rd, 2008 07:43 PM
I have tried 1920 square, but with the same results...
I have tried desaturated and its still really poor quality.
Any other suggestions?
David W. Jones February 3rd, 2008 07:56 PM
Is the problem with the output from your computer monitor or your video monitor?
Scott Aubuchon February 3rd, 2008 10:21 PM
Both, the problem is present everywhere... but the end result will be computer based, the project is not intended for TV distro...
Scott Aubuchon February 4th, 2008 03:56 PM
Anyone have any thoughts? I am really stuck here...
Steve Oakley February 5th, 2008 01:34 AM
yes
inspect the clip settings via selecting the clip and hitting command 9
do they match the TL settings via Command 0 ? if not, there is the problem. are you using a TL preset, or did you go and create a new one.
also, trash FCP prefs, plist, POA and OBJ cache
there is a settings mismatch here somewhere. It looks like FCP is scaling a smaller image to fit a larger one.
Scott Aubuchon February 5th, 2008 07:45 AM
Here are my sequence settings:
http://www.sacreativeservices.com/fo...eq_set_422.png
And here are the image properties:
http://www.sacreativeservices.com/fo...p_hd_image.png
It looks like they are both the same... I will have to try and trash my prefs later this afternoon.
SA
Steve Oakley February 5th, 2008 09:41 AM
your problem is using 1440. make the graphics 1920. the artifacts you see are from scaling the graphic up in size. if your source material is DVCpro or HDV which is 1440 _native_ pixels, the codec can still hand off 1920 to FCP or another app. since what goes on internally with FCP is not documented, this is an assumption. regardless, source video material gets handled by FCP in such a way as 1440 scales to 1920. once you place 1920 based graphics in, the problems will go away. its also possible you may need to change your TL settings to 1920.
Scott Aubuchon February 5th, 2008 12:46 PM
Ok... I tried that earlier and it yields the same results. Although, I did not change my TL settings to 1920.
I will try this later tonight and see what happens.
I appreciate the help.
SA
Nate Weaver February 5th, 2008 01:53 PM
Is that pic above the entire frame scaled down, or a section?
You might be looking at scaling artifacts for the canvas window, and not the true output.
Bill Davis February 5th, 2008 02:21 PM
Looks to me like you have two problems.
First the resolution on your graphics is way low as evidenced by the jaggies between composited elements. Whatever your program is SAYING, that raster looks no better than 72dpi or so - based on what I'm seeing. It's like your program is rendering the low rez PREVIEW graphic - rather than a final high-rez graphic. This can sometimes happen if you drag and drop elements instead of actually IMPORTING them to your timeline as the full rez file.
Second, you're clearly not benefiting from using Alpha Channel gradients at the graphics edges to composite them over the video raster.
Most graphics programs should do this automatically. Again, this looks like you're getting low rez pict files, not the actual high rez graphics with Alpha mattes.
To my eye, something's definitely wrong in your export/import workflow.
Make sure your Photoshop files have transparent backgrounds, then try saving them as TIFF files and when the program asks you if you want to save the Alpha Mattes information in the TIFFS definitely say YES.
But I can't tell more than that just by looking at it.
Good luck
Scott Aubuchon February 5th, 2008 06:38 PM
Bill... I appreciate the response, but I don't believe what you explain is the issue. I am not working with low res files and I am not dragging an dropping.
FYI-- I trashed my FCP preferences and it still looks like crap...
Here are the to files I have been testing: (both versions give the same result)
(1440x1080 PAR=1.33 TARGA)http://www.sacreativeservices.com/fo...f/HDV_1440.tga
(1920x1080 PAR=1.0 TIF) http://www.sacreativeservices.com/fo...f/HDV_1920.tif
Can someone maybe verify if they are bad in some way? You can see my timeline settings above (1440x1080)
And here is an example of it side by side in FCP:
http://www.sacreativeservices.com/fo.../side_side.png
and it looks the same after I render/export... Please, someone tell me I am missing something really stupid :P
Steve Oakley February 5th, 2008 07:35 PM
well I thought I had the Ah-HA Moment but no. one thing is the image you are using is 16bit rather then 8bit. I saved it back out as 8bit, but got the exact same result. I can repro your problem which means your setup is probably ok. the bad news is it looks like a FCP bug.
FCP is somewhere double scaling the image it seems or doing something weird with deinterlacing the image when it should not. I tried this on a G4 laptop with ATI video chip.
one other question. if you render the video, does it still look the same ? reason I ask is that FCP reduces res on some operations, and thats what may be going on here. when I rendered it, it actually got worse. FCP deinterlaced the image and it got even more jaggy.
here is a possible workaround - create a motion project, drop the straight TIF into motion, and then apply the motion project as the title and see what happens.
Scott Aubuchon February 5th, 2008 07:48 PM
Yes... rendering produces the same results
Yeah... tried the motion path and I still had poor results.
I'm plumb out of ideas...
Steve Oakley February 5th, 2008 08:50 PM
this is weird.
the problem is your TIF file. I went into PS and created some text and circles, then saved out a TGA with alpha. they looked fine in FCP. copy and pasted a chunk of your image into the same file, and back in FCP it was messed up. there is something weird about it, most likely because it started as a 16bit image. what I can suggest now is to redo the image entirely in 8bit and then all should be good.
whats odder is that the problem is only really on one side of the image and looks like a premult problem of some sort that doesn't show up in PS, but in FCP there is some color transform going on that brings it out.
Scott Aubuchon February 5th, 2008 10:27 PM
Wow... I wish I was getting the same results... I still cannot get any versions, whether it be 8/16 bit, tiff/targa or whatever to import properly.
Steve Oakley February 6th, 2008 09:07 AM
try reinstalling QT, which ever version you are on as QT is ( should be ) handling the image import. go to apple and get the stand alone installer. if you want to go back to 7.3.1 find Pacifist via google which will make it easier. if you have a 3rd party video IO card, I'd also reinstall that after doing QT. hopefully this cures it.
Scott Aubuchon February 6th, 2008 10:01 AM
Well... I really appreciate your helpful advices, but... it did not work.
I was successful in downgrading to 7.3.1 and I removed all third party plug-ins to QT, but still looks all messed up.
Steve Oakley February 6th, 2008 11:24 AM
hmmm. well this is all the standard quick painless things to try. this is coming down to the more painful.
1. reinstall the OS via Archieve and Install which will keep all your fonts and other 3rd party bits plus prefs. takes about 40 minutes and is fairly painless.
2. reinstall FCP only
3. reinstall PS
update FCP, OS, PS.
now one point here. the image you posted up also messed up for me. a new image I created here worked, and I'm posting it back. the text and circles I made look clean here, lets see if they look clean for you.
won;t let me UL..... email me & I'll send it direct
Scott Aubuchon February 6th, 2008 04:33 PM
Ok... so I went through the process of reinstalling, still no luck...
I am starting to heavily lean towards bug, unless someone can prove otherwise.
is nobody overlaying graphics in FCP? I would think this would be a known issue with a workaround.
Andrew Kimery February 6th, 2008 05:54 PM
Scott,
I grabbed the examples you posted and dropped them into a ProRes 422 1920x1080 sequence (both 60i and 23.98) w/some DVCPro HD footage. There was a slight difference between looking at the source image in the viewer and looking at the rendered image in my timeline, but nothing as bad as what you seem to be seeing.
I'm running FCP 6.0.2, QT 7.3.1, and 10.4.11 on a dual 2ghz G5.
-A
Scott Aubuchon February 6th, 2008 06:45 PM
Ok... I whipped up a short screen cast that shows what I am doing. Maybe I am doing something totally incorrect... which is causing my troubles.
check it out (~7mb - 1920x1200 - MOV):
http://www.sacreativeservices.com/fo..._hdv_still.mov You may want to save it off, it might hose the browser because of its size.
Andrew, is this how you did it?
Andrew Kimery February 6th, 2008 07:15 PM
After looking at your movie it looks like you and I are seeing the same results. The stills you posted looked a little worse, but that just must have been compression from making the still image. Have you tried exporting a test QT and/or looking at it on a TV/b'cast monitor to see if it still looks messed up?
-A
Scott Aubuchon February 6th, 2008 07:52 PM
Yes, I have rendered it out and viewed on both computer and broadcast monitor with no difference in quality.
Steve Oakley February 6th, 2008 10:43 PM
Ok, I can both repro and fix a related problem, sort of.
I placed the TGA file into a ProRes 1440X1080 project. TGA was 1920X1080
when I placed Generators->Color Solid (FXplug) under the TGA in V1, I got an FCP error "Your graphics card can not render this in a sequence of this size" and I had what looked like low res render. what the $#@#$!!!!! I removed the Color Solid and replaced it with Generators->Color (AE api) and everything was good.
what graphics card is in the machine ? do you have another card to swap out ? apple never says exactly what its rendering on the graphics card, but maybe this is the problem - GPU vs CPU rendering. wouldn't be the first time. the laptop is 128mb Vram, what about your card ? now I want to try this on my X800 256mb in the G5. I'll email you the project file
Zalee Isa February 7th, 2008 02:54 AM
This article might help you in some ways:
http://www.rippletraining.com/engine...n=docs&doc=418
Aric Mannion February 7th, 2008 11:07 AM
I only do this stuff in after effects, but I do struggle with final cut and graphics once and a while. Is your video interlaced? If you check your sequence settings try your fields set to none. Export it to h264 or whatever and don't bother looking at it in the canvas at all. And I guess setting motion quality to best could help...
Duncan Craig February 7th, 2008 12:43 PM
Have you tried switching effects handling off?
I always have some problem or other like this on every project. Sometime I'll try to get to the bottom of it. It's always something different however.
Have you tried rendering to a self contained quicktime in motion and use that in FCP?
Good Luck.
PS I never use tiffs, always PSD or tga
Scott Aubuchon February 7th, 2008 02:32 PM
Originally Posted by Steve Oakley (Post 821735)
what graphics card is in the machine?
I have the Geforce 7600 GT (iMac version)... Hopefully my new MacPro arrives soon, which will have the 8800 card.
I will try what you suggest later tonight, my real job is getting in the way! :P
Scott Aubuchon February 8th, 2008 09:19 AM
still no luck with all the suggestions... I even tried making a motion template, which imports beautifully in the viewer (and looks perfect in motion), but as soon I drop it in the time line, it turns to garbage...
I render, export and it looks the same.
I tried all the suggestion from the ripple training article... no luck.
Now, when I import other motion templates (Tech Blue- Lower Third), it works fine... maybe slightly blurry, but more than acceptable.
What else?
Duncan Craig February 8th, 2008 09:54 AM
Did you try rendering in Motion and adding the finished quicktime into FCP?
Scott Aubuchon February 8th, 2008 09:58 AM
yeah, I rendered in motion using the animation settings... the outputted mov looked perfect... that is, until I dumped it in my timeline. :)
I am really at a loss now...
Aric Mannion February 8th, 2008 10:19 AM
So only the red graphic looks bad, and the blue one looks ok?
Scott Aubuchon February 8th, 2008 10:40 AM
funny you mention... I tried rendering in blue, thinking it was having a hard time dealing with red (which isn't uncommon)... wrong... looks just as bad.
Scott Aubuchon February 8th, 2008 01:28 PM
Interesting... I changed to uncompressed 8 bit (in the sequence settings) and it looks MUCH, MUCH better!
But, this kind of hoses my work flow, as I have to re-render footage. Not a show stopper, but a BIG thorn in the side.
***EDIT*** Once I rendered, it looked like POO!
Scott Aubuchon February 8th, 2008 09:52 PM
As I said above, I have been working this issue in multiple forums... and someone pointed out something interesting... He was drawing to the conclusion that the renders are high quality images (4:4:4) and the prores is lower (4:2:2) and they will never match. I am a confused by this as its a bit over my technical head.
Anyone have an opinion on this?
Scott Aubuchon February 9th, 2008 06:30 PM
this thread has kind of dried up on me... anyone have any other suggestions?
Eric Goodspeed February 10th, 2008 03:55 PM
Check it out
http://www.kenstone.net/fcp_homepage...p_spencer.html
Steve Oakley February 12th, 2008 01:17 AM
it should not cause the problem.... BTW, is what you are seeing going out to the NTSC or HD monitor the same way ? or only the canvas ?
