install CS3 then upgrade to leopard?
Are there reprecussions to doing this? My leopard DVD that came with my mac was unusable and will take up to 10 days to get a replacement. If I install CS3 now and upgrade to leopard will there be problems? Should I just wait until leopard is installed before installing software?
As mentioned in many threads, the "upgrade" path for Leopard will introduce a plethora of issues with any pro-video application. Leopard most certainly needs to be a clean-install, so if your plan is to run a 10.5-based system then either goto the local retailer and pick up a copy or wait for your disk to arrive and do a proper OS and application installation.
Search the threads and you'll see dozens of posts with a myriad of issues on "upgraded" systems and why a clean-install is so important. |
Along these lines, I have CS3 master suite. When I got it, the installer would not work. After much googling around I found that my beta version of safari was the reason. I've not upgraded to Leopard but I am assuming that it uses the newer version of safari which, I guessing, will break my CS3 install again. If/when I upgrade to Leopard, do I need to get new install disks from Adobe to install my CS3 suite? Has anybody else run into this or am I worrying about something that is not a problem.
The beta-version of Safari did cause many app-related issues however, Leopard is using a final-release version of Safari, not beta. As long as you do a clean-install of Leopard, not an "upgrade" then when you install any 10.5-compatible CS3 app you'll be fine.
Be sure to check the Adobe website for the list of Leopard-compatible CS3 apps prior to installation. |
| All times are GMT -6. The time now is 10:24 PM. |
