-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP 6 - Preview over Firewire question (https://www.dvinfo.net/forum/final-cut-suite/109290-fcp-6-preview-over-firewire-question.html)
Nick Weeks December 1st, 2007 02:47 PM
Can FCP 6 preview HDV video, downconverted to DV realtime over firewire to an external device so I can preview my HDV video from an HDV timeline on a SD monitor?
I read somewhere it was possible but couldn't find much info on Apple's site about it and was hoping someone could confirm it.
Andrew Kimery December 1st, 2007 05:56 PM
Yes, FCP 6 will down-convert HDV into DV on-the-fly so you can preview on an external SD monitor via FW.
-A
Andy Mees December 1st, 2007 09:29 PM
it works a treat Nick but will only provide a letterboxed output, it won't do an anamorphic output (16:9 stretched to 4:3) so its great if you are viewing the downconvert on a 4:3 monitor but not so great if you only have a 16:9 monitor
i created my own easy setup for working with XDCAM HD with DV preview, but probably the easiest way to get this to work is, when ready to edit, simply re-choose the DV NTSC Easy Setup ... at that point you should see Apple Firewire DV as an external video option in the view menu
hope it helps
Andy
Nick Weeks December 3rd, 2007 06:36 PM
Great. I have a wonderful broadcast monitor for SD that I'd like to use for color tweaking with my HDV. Should work great because its a 4:3 monitor
Thanks for the input
