Soundtrack Pro really can't export properly can it?
I'm exporting a 6 minute multi-track project. Nothing elaborate, nor large use of effects apart from normalize and EQ.
But when exporting to an .aif, the audio at very random points becomes sped up, higher pitch, and on different tracks. This is an absolute shambles, the audio plays absolutely fine in the timeline, and i'm wondering if there's any way of rectifying this export problem? (other than avoiding soundtrack pro like the plague?) any help at ALL would be much appreciated. Neil |
I personally have never had Soundtrack work for me. return trips with FCP have always been a mess.
Such a shame...
It sends the multitrack project out with high hopes then it comes back sounding like a hobo.
can you recommend an alternative to Soundtrack? |
Is everyone having this trouble and problems?
As someone interested in purchasing FCS 2, this is interesting to know... Other opinions? |
I run Soundtrack on FCS 2 and the problem is that the concept of it's workflow with FCP is fantastic, which is why i keep going back to it, but it's just NOT ready for release, it just doesn't work properly.
The problem lies with the export, and but the audio plays PERFECTLY when played from the timeline. With this, there is only one way of making Soundtrack Pro usable at the moment and this is by connecting the audio out jack to the microphone input jack, then playing the audio on the timeline whilst simultaniusly recording the computers output audio. So i'd also like to hear comments/advice about this absolute shambles also!! |
A bit sorry to hear about this... any official complaints? Anyone know if Apple is busy with an upgrade fixing this export-bug? |
I'm not.
But then I'm only ever converting 2-track stereo to aiff. For me, it works fine doing that. |
I've been using Soundtrack Pro a lot from Final Cut Pro, but only 1 clip at a time (so it's not a multi track project in Sound track). Never had a problem.
I haven't tried multi track projects. |
I will proceed with caution, saving often and double checking everything, but at least for now it works for me. If nothing else, surround sound is sooo much easier to do now than it was faking it with the old STP. :-) - Martin |
Had to use a multitrack project as well today and also ran into the export problems. A search on the internet revealed that Soundtrack screws up if you mix files with different sample rates, or if you try to export to a file with a different sample rate that the audio in your multitrack project.
After converting all my audio clips to the same rate, it now exports ok. Still a major bug that should have been fixed by now. |
a hah! a solution!
Thanks very much for that, i'll certainly give it a go. How is the best way to convert sample rates by the way? What would you recommend? In soundtrack too? |
Yes, converting is quite simple with Soundtrack:
open the file with soundtrack pro Choose "File | save a copy as.." and in the sample rate combobox choose the right sample rate Hope it helps for you too, Winfried |
| All times are GMT -6. The time now is 07:12 PM. |
