Best configuration for editing on new mac book pro with cor 2 duo and final cut?
Now that the new mac book pro has core 2 duo processing what is the best set up for editing hdv on the mac book pro and final cut studio 2 and can I get an hd or blue ray burner installed in the set up. I would like to get some opinions on the best set up in the 6500-7k range. I am using a Gyhd100ua for my shoots. Thanks in advance for your opinions
im wondering about the same thing... is FW400/usb2.0 too big of bottleneck? would FW800 make a difference? external raid?
thanks |
400 works fine. 800 is faster, though.
I recommend 7200rpm drives over the 5400 internal drive (ie, an external drive), but that's as much as you'll need, probably. USB2.0 is about the same as FW400. |
I would avoid USB. I know, I know, people use but I think the vast majority of people who do have probs. Although its speed is faster than FW that speed is delivered in bursts, not suitable for working with video
If you are working with standard DV then a FW 4 external at 7200 rpm would be fine. For HD you would want to go to FW 800 or some kind of eSATA option. Yes, you can get an HD DVD burner. At this point, there is no direct Blu Ray support for a Mac. You could only use a Blu Ray burner to burn data discs with Toast but you cannot make a Blu Ray "movie" disc. So if you have to have a Hi Def disk, HD DVD is the way to go, it is supported in DVD Studio Pro. |
USB 2.0 works, but FW is definitely superior when working with Macs, true. It's sorta the other way around with PCs as well.
i forgot to mention that im PRIMARILY working with hdv material.. 1080i 24f usually.. i edit it mostly at school on the dual 2ghz g5's, so i was hoping that the dualcore 2.2-2.4ghz macbook pro would be a bit better atleast.. i read a review that seemed to state that it was totally workable.. but other user comments on this board have not been very supportive..
i have a 500gig 7200rpm external drive that i use mostly right now.. i could buy an external raid enclosure for a couple hundred bucks but im not sure if its really worth it unless working with several clips at once? like picture-in-picture etc.. |
You may find yourself tweaking a lot of settings as you go along --- especially in FCP itself. Depending on what you're doing, some fiddling with the Real Time settings, on a sequence-by-sequence basis, may be necessary. I'm running a 2.4GHz new MacBook pro with the wider screen and with 4GB RAM. External storage is a 1TB Lacie FW800.
Now, if you're running plain old HDV, cutting it up and slapping the clips together, you'll no doubt be fine (you may need the additional RAM, though). However, the moment you start doing effects or colour correction (and not even necessarily using Color), things may start to choke. I heard somewhere (and this is hearsay) that 8GB RAM is really what is needed for all of this stuff to run fast, together with at least a fast quad-core. Perhaps in my next life ... I've even found that running a denoise and degrain filter on SD footage makes the machine choke a bit. For things that don't really matter, I've now started downconverting the HDV footage (from the Canon HV20 or the A1) in-camera before I capture into FCP. This helps. The rule I'm now using: two relatively simple filters per clip, max. Even so, things do slow down --- even considerably so. You may also make some progress with Motion, but that will soon choke as well. I don't know how complex your projects are, but as someone said to me a while ago: no-one in their right minds would try and use a laptop for serious video work, especially with Motion and Color. Dunno if this helps. If there is any way that you can lay your hands on one and play around with it, it will be a good idea. If you can't, well, read and ask as much as you can. Good luck Carl Mischke Jo'burg |
does it make much of a difference if you're editing native hdv or apple intermediate or prores422? or the 'hybrid mode' where it only renders the transitions etc in prores422?
From my limited experience cutting HDV on a 2GHZ Imac with 1.5gig of ram, of a 7200rpm external drive running FW400, simple cuts etc and moving stuff around the timeline works fine. Grading and transitions will likely need rendering, but the rendering of basic transitions will be pretty quick, so it isn't a huge head ache if you aren't doing finicky stuff and aren't on a massively quick turn around.
Talking tower
Gary
My advice to you would be to go for the biggest, meanest MacPro tower that you can afford, with as much RAM and as stong a processor as you can dig up the money for right now. Remember that you can add little bells and whistles (or even big bells and whistles) later on --- which you cannot do with the MacBook Pro. But again, it depends on what you want to do. It does really well if you simply cut and order clips, perhaps do a bit of brightness/contrast or similar. But the moment you want to start getting off the wall with something more creative (to say nothing about Motion) you may find yourself frustrated. You may well find yourself having to render a lower third title overlay (or accept some frame dropping). I've played around with the render settings and the RT settings for some time, but I have yet to come up with some magical solution. Just a bit of what I experienced --- naturally (the disclaimer follows): what I experienced may not apply to others, depending on what they're using the MacBook pro for. Carl Jo'burg |
Thanks all for the information I am now looking into getting the Mac Pro tower.
