-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   How do I see the audio spikes and sound lines in Final Cut Pro 6 timeline? (https://www.dvinfo.net/forum/final-cut-suite/104648-how-do-i-see-audio-spikes-sound-lines-final-cut-pro-6-timeline.html)
Jimmy Conway September 29th, 2007 06:56 PM
I'm having trouble figuring out how to show the spikes and sound lines in the audio tracks in the timeline using Final Cut Pro 6. I've used Premiere and it is just one click away. I can't seem to find it with FCP. First time using FCP. Any help is appreciated. Thanks.
Kevin Harrington September 29th, 2007 07:02 PM
If you control-click on the Sequence in the browser and go into Sequence Settings, there is an option to display waveform in the timeline.
Daniel Ross September 29th, 2007 07:09 PM
Or, faster, the little flyup menu on the bottom left of the timeline, check "show audio waveforms".
Jimmy Conway September 29th, 2007 07:22 PM
thanks a lot. it took me a good half an hour playing with FCP and googling for an answer with no luck yesterday.
