Audio won't load on Dvd Studio Pro
I have done this a lot of times with compressor and Dvd Studio Pro without a problem, but now it's giving me a total headache, perhaps someone will help me with this issue.
Audio won't load from compressor, though i can see from the file before dropping it into the menu that there is an AC3 file audio. Once I drop it into the track, it only shows the video, the audio does'nt load. What am I doing wrong! Anyone? |
Are you sure your audio format is supported by DVDSP? Have you tried using the Import command instead of dragging and dropping? Maybe it might be different.
DVDSP only automatically brings in the corresponding audio if (a) it is named the same as your video track - apart from the suffix, and (b) you have told it to do so in the preferences.
Rather than sort the above, you can either just drop the audio on the track after dropping the video on it, or select both audio and video tracks manually (by shift+click) and drop them both on the track together. |
Martin
I followed your advice by loading them manually and it worked, now I can deliver my project. Thanks a lot! |
