-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Fcs 2 Crash (https://www.dvinfo.net/forum/final-cut-suite/101398-fcs-2-crash.html)
Vishad Dewan August 15th, 2007 11:04 AM
Fcs 2 Crash
I just finished a FCP project and wanted to export it to Compressor; unfortunately, Compressor wouldn't launch; it kept crashing. So I tried installing and reinstalling the software, with no luck. I decided I'd completely delete FCS 2 and reinstall. Did that and now when I try to open my existing project file into FCP the app crashes.
I've deleted the .plist files but the problem is the same.
I really need help with this!
Tim Dashwood August 15th, 2007 11:48 AM
Yikes! Did you call Apple tech support yet? They may have already documented the problem and know of a conflict somewhere.
Your project probably won't open until you run all of the pro app updates after the fresh re-install.
Mike Hanlon August 15th, 2007 07:56 PM
There are software updates for the FCS 2 suite. I had some major troubles until I got the updates.
