-   Final Cut Pro X (https://www.dvinfo.net/forum/final-cut-pro-x/)
-   -   Audio Reverb (https://www.dvinfo.net/forum/final-cut-pro-x/530948-audio-reverb.html)
Scott Hepler January 22nd, 2016 08:28 AM
Audio Reverb
Hey guys, if I could ask for some advise please. I end up with a bit of reverb from interviews where I am stuck in an office or hallway, small room etc. I have not been able to find a good way in FCPX to reduce it. There are a lot of ways to introduce reverb but maybe I just haven't found it. I am definitely not a great audio guy, I have good mics and I try to get it as clean as possible but sometimes I just get stuck. I found a plugin for PP called reverb reduction (de-reverberation) from acon digital, and for $100 plug in it looks like a really good option but it won't work with final cut. I really would like to have iZotope but for $350 and then I have to round trip, so if I can find a cheaper plugin for fcpx that would be ideal. I would rather not have to round trip audio, but maybe that is what is necessary. So does anyone have any plugins for FC that they like for these types of situations where you just need to sweeten a little bit?
William Hohauser February 2nd, 2016 02:54 PM
Re: Audio Reverb
This was just announced:
AudioDenoise - Magically remove audio noise | CrumplePop
Who knows how well it works.
Andrew Smith February 2nd, 2016 05:31 PM
Re: Audio Reverb
The Izotope RX plugins are also supplied in the VST plugin format which means that you can use them directly in your audio editor if you wish.
Andrew
