macbook pro
I need a laptop to edit final cut pro x on, I have a mid 2012 mac mini, ssd, 16 gigs of ram, it is so slow I cant use it. don't want to spend all the money for a new one, and I understand that the non-retina version is the one to own. U can change drives & ram. What models of the 15 inch are good enough for 2 to 3 layers of hd.
thanks, Charlie |
Re: macbook pro
You'd actually be better off considering a new iMac. You get a whole lot more for your money over a MacBook Pro.
Re: macbook pro
Do think about a Retina though. It's really a fast system, dream to edit on in FCPX.
We are using 3 of them, and we are surprised every day about their speed. |
Re: macbook pro
You can't compare Mini to MBP to iMac without knowing the specs.
A Quad i7 Mini could outperform a Quad i5 iMac in many CPU based tasks. If your Mini is a Quad i7 then there's problems with your system. If your Mini is a Dual i5 it will be slow. A MBP Quad i7 with GeForce 1GB 650M would outperform an iMac Quad i5 with Geforce 512MB 640M I'm not sure why you understand the non retina is the one to own. You need to understand the different models and what they offer vs your needs. The best possible Mac for FCPX would probably be 27" iMac Quad i7 with 2GB GeForce 680MX The best MBP would probably be 15" MBPRetina 2.8GHz Quad i7 with 1GB GeForce 650M which would be slightly better than 15" MBP(non Retina) 2.7GHz Quad i7 with 1GB GeForce 650M. Neither of which would be quite as good as the aforementioned iMac due to the GPU. |
Re: macbook pro
I guess my non-retina request was because of limitations of adding ram & hard drives. Maybe a non retina, adding a ssd & 16 gigs of ram. My core I-5 mini is sooo slow in editing. I added a ssd & 16 gigs of ram. Killing me. Got to buy a unit today & get back to work.
Re: macbook pro
In the current models the 15" MBP can max out at 16GB RAM.
The current 15" MBPretina can come with 8GB or 16GB preconfigured. Basically the 15" MBP non Retina can allow you to decide to add RAM later but if your goal is 16GB you can get that with the MBPr at time of purchase. Personally I don't see adding RAM later as a big advantage unless you want to start with 8GB. Yes a MBP non Retina can allow you to add another drive, true. On the other hand the MBPretina has two Thunderbolt ports and some might find that useful. |
Re: macbook pro
I went with a MBPretina with everything available and added the thunderbolt display. The big screen is wonderful to work with and the 3 extra USB3, 1 firewire 800, ethernet connection and additional thunderbolt port are very useful. It even has a charger cord for the laptop so you don't have to pull the charger out of the bag. Plus the laptop is super light and portable for going on the road. It is a great option for a one man show.
Re: macbook pro
There is no FW 800, or 400, on a retina MBP.
Re: macbook pro
Re: macbook pro
Re: macbook pro
Maybe I should repeat this again. Apple sells a Firewire to Thunderbolt cable. I'd rather have the more flexible Thunderbolt port and just get the simple cable.
Re: macbook pro
Re: macbook pro
Re: macbook pro
Also, it's not 29"... it's 27" Check your facts, man! |
Re: macbook pro
