moving FCP X project/event locations
I have my FCP X projects on one internal Mac Pro drive, and events on another. I'm going to take those out, replace with much larger HDs, and mount the old ones when I need to with an OWC Voyager dock.
My question is: can I just use the Finder to copy the Projects and Events folders to the new drives, or do I have to go through FCP to move everything? I'm guessing it depends on whether FCP stores some ID info of the specific drives in its database. Thanks. |
Re: moving FCP X project/event locations
That will work but it would be better to move the files by choosing the project and check the choice to move the associated Event folder.
I have done it in the Finder, copy things, and it didn't went wrong.
If you place it in the Root folder of a new drive again, and your media is in the same place (and you can relink anyway since the 10.0.3 update), you shouldn't have any problem. That being said, Apple recommends doing it via FCP X itself, and I can imagine why. A bit more 'sure' that the software will copy anything it needs correctly. |
Yep, if you don't do it within FCPX, then you will have to relink your files simply because you will be copying them to a drive with a new name then the original. Well... that's what happen to me anyway after creating a new RAID0 and copying the files from the original drive to the new RAID. Unless Im mistaking, you will have to do it outside of FCPX because you won't be able to run 2 drives with the same name at the same time.... right?
| All times are GMT -6. The time now is 06:24 AM. |
