-   Final Cut Pro X (https://www.dvinfo.net/forum/final-cut-pro-x/)
-   -   Possible to build XSAN setup for Final Cut using Lion Server? (https://www.dvinfo.net/forum/final-cut-pro-x/500941-possible-build-xsan-setup-final-cut-using-lion-server.html)
Arne Johnson September 21st, 2011 05:06 PM
The update for Final Cut X includes support for XSAN, and the further I looked into it, looks like XSAN is built into Lion? So, theoretically it seems like you could do an xsan on a Mac Mini server for $999:
Apple ? Mac mini with Lion Server ? Now with quad-core power.
Mention of XSAN capabilities in Lion here:
Mac App Store - OS X Lion Server
We're desperately in need of a server setup in our office with a RAID array and trying to figure out the best/cheapest way to go about it. This gives a glimmer of possibilities at least. Did anyone try this in Final Cut 7?
Arne
Nigel Barker September 24th, 2011 03:04 AM
Re: Possible to build XSAN setup for Final Cut using Lion Server?
Are you sure that XSAN is what you want? The Fibrechannel infrastructure will cost many times the price of a Mac Mini with Lion Server although there is now a Thunderbolt->Fibrechannel interface available that will make this configuration possible. Promise releases a thunderbolt to fibre channel adaptor for macs- The Inquirer
We just use a couple of Synology DS1511+ NAS devices for shared RAID storage Synology Network Attached Storage - Products :: DiskStation DS1511+
Arne Johnson September 26th, 2011 11:32 PM
Definitely NOT sure that's what I want! We're just trying to find a budget system to run two workstations with Final Cut Pro off the same files. Can you tell me more about your setup? Do you have a server between the NAS and your computers? Are you able to get ProRes to run? What cost range total?
Nigel Barker September 27th, 2011 09:32 AM
If you are talking about sharing files as in a proper library system & being able to check out & check in files then a NAS is not what you want but instead is Final Cut Server (no unobtainable) or similar. If you just want to be able to maintain one copy of files that you can both work on but not literally using the same file at the same time (you need to co-ordinate access between yourselves) then a NAS could be the way to go. The Synology boxes are good value & very fast. Accessing a RAID-5 volume over Gigabit Ethernet is similar in speed to accessing local disk in my Mac Pro. A direct attach RAID array or striped internal disks on the Mac Pro would be faster though but we don't have real heavy projects that are going to hammer the disks. We tend to copy files from the NAS to a local disk & then work on them there but sometimes do edit over the network for convenience although scratch disks are always local. You can use one Ethernet port on the each Mac Pro just for accessing the NAS over a private LAN for the best performance.
Arne Johnson September 27th, 2011 06:45 PM
Very cool, and thanks so much for taking the time...a couple more questions. So, are you saying there's no file server, just networking directly from Synology to workstations? Are you using an ethernet switcher or just a normal hub? And lastly, I just want to confirm...multiple computers can be accessing the drive, but not the same files, yes? So, one project could be working simultaneously off that system as long as it's not sharing files?
Sorry to pepper you with questions, but this may just be the salvation we've been looking for!
Arne
Nigel Barker September 29th, 2011 10:26 AM
Correct there is no file server or rather the NAS is the file server as it's actually running a version of Linux but all interaction & management is done through a web browser. The Synology management interface DSM is really nice DiskStation Manager 3.2 Beyond NAS server operating system Synology Inc. Network Attached Storage NEW NAS Experience
We use a Gigabit Ethernet switch.
Multiple computers can access the files as there are shared using AFP (& SMB for Windows computers). In fact you can be accessing the exact same files just so long as you are not trying to write or modify them. You could have all the source clips on the NAS device but store the project files on local disks or in a private directory on the NAS.
We also use the NAS for Time Machine backups.
Arne Johnson September 29th, 2011 01:15 PM
Thank you so much! This is life changing info...I just ordered the Synology 1511 with 5 3TB drives for less than $2000. I still can't believe it's going to be this easy. You are the awesome...
Arne Johnson October 4th, 2011 10:33 PM
Synology NAS installed and working like a charm!
Arne
Nigel Barker October 5th, 2011 12:18 AM
Arne
Glad to hear it. To my knowledge you are the second person to buy one of devices on my recommendation. I am seriously impressed with the Synology NAS. It is a very sophisticated piece of kit. Very fast & expandable. Quiet too so can happily sit in the office although it can be located anywhere at the end of an Ethernet cable. We are not using advanced features that would improve performance & management like network link aggregation & using iSCSI but for the moment just using the basic file serving capabilities is all we need. We now have two 1511+ boxes & one DX510 expansion box but can still add another couple of DX510s to double the storage capacity if necessary.
