Don't be hoodwinked twice
An interesting experiment has cropped up, where people disappointed by FCP X are thinking that the new, $49 dollar Compressor add-on will make their FCP 7 encodes faster.
It won't so don't waste your time and money. Compressor 4 won't talk to FCP 7 - or any other earlier version. C4 is also not 64-bit so it's not capable of using all the cores you might have (like a new 12-core system), so no blistering speed increase. And the output times are just as painfully slow as Compressor 3, so there's been no code-monkey tweaking of the actual encoding engine. It's the same old Compressor with a few more presets and a minor interface tweak - and that's it. As I've posted before in my encoder shoot-out, the fastest software-based encoder today for the Mac is Episode Desktop from Telestream. Sorenson comes in second by a wide margin and then there's Compressor with a molasses-slow 3rd place. If you've got the cash to afford the external hardware, the fastest and highest quality encoder is unfortunately PC only. It will run on a $300 Win XP box but the hardware/software package will set you back around $3K to $6K depending on who's solution you purchase. Ah, but what can a dedicated encoder like that do for you? How about taking an MPEG-2 encode that would normally take Compressor 20 hours to complete would be done in less than 3 hours with these kinds of rigs. How about that. |
Re: Don't be hoodwinked twice
Thanks for the info. I was actually considering that.
Matrox MXO2 MINI with MAX is a fast hardware H.264 encoder and it works with both old and new versions of Compressor. IIRC it was about $800.
I'm sorry, my experience so far is that C4 is faster for certain codecs after I set up the QuickCluster. Converting to ProRes is remarkably fast. Converting to H264 is faster as well. QuickCluster seems to be under better control so I have been able to increase the number of rendering instances. Tonight's job of rendering 25 minutes of HDV to DVD took about 10 minutes. I seem to recall that HDV to DVD used to take longer. But some codecs don't seem to be different, DV-NTSC for example.
I still have to export from FCP 7 as QuickTime files as I always have had to do with C3 when using the QuickCluster anyway so that part of my workflow isn't changing. But with FCPX I can send a project direct to Compressor and use the QuickCluster without having to export a fully rendered QuickTime file first. The numerous deficiencies of FCPX aside, it's already been useful in assembling rough footage and making DVDs and web files for clients quickly. |
In my case I use it with both my notebook (Express/34) and my Mac Pro (PCI).
Although don't buy the dongle version if you have a Mac Pro tower or the latest Macbook. Encoding is quicker with the dongle unplugged! |
We only use the Elgato dongle for proofs & such like where time is importatnt as the quality while very decent is not as good as when using Compressor or MPEG Streamclip. |
The marketing documentation makes you believe it's a hardware assist when the dongle is plugged in. But actually it takes over the entire H264 encoding process. Fine if you have a 3 year old Macbook Pro like me, but a colleague with the brand new topline Macbook Pro finds that the encode is faster without the dongle plugged in. The same is true with my own dongle when used on my 8 core tower. |
I agree with Robert on his views of Episode. Very nice and speedy encoder. I recommend it to everyone that processes mpeg2 files on a daily basis.
But to be fair, lets compare like with like: Compressor 4 in the UK is £30 and Episode is £329. Probably money well spent if you encode very regularly but expecting software to be as good as a similar product 11x as expensive is unrealistic.
A common theme of all Apple's pro video editing products, they are good but could be improved. Subsequent new versions add features but the code base remains the same and the product stagnates. Smaller more focused companies like Episode can only sell their products if they are better.
Apple can sell Compressor for less because they can make money in other areas, have volume advantage, as a result aren't as driven to provide software that uses the latest and best methods. I get the feeling there are a lot of internal politics driving decisions. If you can't convince the higher ups that updating Compressor to 64 bit or developing better encoding methods are going to result in more sales then I doubt its going to happen. Current trend is to sell to more users at a lower price. |
| All times are GMT -6. The time now is 10:48 AM. |
