Direct-to-Disk — Canon XH-A1
Hi everyone,
I'm a Mac user and I'm thinking of getting a Canon XHA1, which I'll use exclusively for studio capture... I'm also thinking of getting some kind of D2D capture workflow, for both the redundancy (TAPE capture + D2D) and for real-time monitoring/evaluation of shots... As I understood from the multiple threads I've read, my 2 choices are: 1. Firestore FS-C 2. Adobe OnLocation With the Firestore I would have D2D capture, but no real-time monitoring of the shooting... For this reason, I'm kind of inclined to go the Adobe OnLocation route... As I understand, besides capturing D2D, the software will allow me to monitor the shooting in real time. Is that right? Even when shooting HDV? I'll be using a MacBook Pro (plus BootCamp, since OnLocation is Windows only). Should I expect any problem from this setup? Do you guys have any advice or opinions in favor or against OnLocation??? Assuming everything is fine with OnLocation, will the screen of my MacBook Pro 15" be large enough for previewing the HDV video or should I get a larger external LCD??? If anyone can share some insights, I'll be very very grateful... I'm a total newbie and although I've already read a lot of threads, there are several concepts that remain unclear... Thanks in advance!!! |
The big problem with capturing to a laptop is it is clumsy. One of the hard disc recorders, such as the Firestore, is much more portable. It can be mounted to the camera or attached to a belt.
Buddy |
Thanks Buddy,
As I said, I'll use the XHA1 exclusively for studio capture... No field work, at least for now... So, besides the clumsiness, is there any other problem I should be aware of? Edit: Besides direct-to-disk recording, my interest in Adobe OnLocation is the real-time monitoring of the shooting... So, can it be trusted??? I've read something about latency issues (from .5 to 2 seconds depending on the thread). |
I've never seen 2 second latency, but about a half-second seems to be typical for HDV. (DVRack 2.0 HD)
What this means: The monitor is fine for lighting, focus check, framing, etc. You must use your camera lcd or viewfinder to follow action by zooming, tilting, panning, or quick focus changes. But I'd be doing that anyway. A very valuable monitor, even with latency. |
Just a thought... EDIT: I just noticed you said MacBook Pro... I dont believe Canon Console has a Mac version.. Sorry. |
You can record straight into Final Cut -- I do it with a 1.67 powerbook and it works great, even with a fairly long (10') firewire cable. I roll tape as a backup, but have never needed it.
Be aware that there's a 20 second lag between starting the record in Final Cut and when it actually starts recording, though. |
