Some competitive devices...
I realize that most of you guys are concentrating on Firestore (name your model) and all that, but there are a few others as well. Even while I know I may record directly to a laptop computer via Scenalyzer software which I have acquired, I am still interested in smaller portable devices, Firestore and other products.
Have any of you had any experience with the following?: http://www.mcetech.com/quickstreamdv.html An outfit called "Shining" (something like that) also has a competive model, noting that none of them have the small screen that gives a comprehensive status. They are cheaper then Firestore (model) per hard-drive provided. ON EDIT: Here is the link on the "Shining" outfit that promotes their "CitiDisk" unit: http://www.shining.com/products/tota...n/citidisk_dv/ What are your thoughts on these competitive devices? Bill |
Hi Bill
You could also look at a similar device by Laird called CapDiv. I think it's around $1000US. It's compatible with PC and Mac. I looked at buying one of these a while ago but decided that it was a bit pricey here in Australia. Phil |
What I want to know is any experience others have had with units besides the Firestore brand. Having a LED display is attractive, which the others do not have (so far as I can see) so before I buy, IF I buy, I want to benefit on the experience of others. Anyway, thanks for your input, Phil. Since I do not need to have it lugged around with the camera (it being on a special tripod mount in my car) my laptop can easily be placed to one side, on the passenger seat suitably restrained so that it don't go flying if I get rear-ended in an accident, or prying eyes being tempted to break into my cart to steal it while I am at some resturant having a meal. :) I have "Scenalyzer" software that will easily process from a firewire link onto it's own hard-drive. Even with the small unit, like the Firestore 4 Pro (I am considering), the lap top computer, safely stored out of sight in my car, would contain my editor software where I can first transfer from the smaller unit (or it's own hard-drive) onto an external 300 gig hard-drive from where I can then edit it at my leasure in some motel along the way. Either way, it's money, money, money and more money! :) Bill |
William,
If you do a search with "quickstream" or "citidisk" or "shining" a a search criteria, you should get a slew of threads. In short - no one (that I have heard from) has had any luck with the quickstream/citidisk/shining device - which are all the same thing basically. The device either, doesn't work, or is not reliable. Also search for "Pyro drive" and "nNovia" for some other alternatives. |
I wanted to hear from a "professional" and get good advice, and you did exactly that! :) Bill |
I got a DSR-DU1, some kind of ancestor to all DV drive, and until know, i found it rock solid and very reliable (professional sony style).
Strangely it was realeased to early, not really advertised, and has almost disappeared (price was probably to professional too , about 2300$, but fortunately a got 2 of them for 1200$, 600$ each) only drawback is that it is not really a PC firewire drive, so you can see it more like a tapeless recording system , than like a real firewire drive. http://www.vistek.ca/deals/details.a...&mkt=clearance but you can probably get it for less http://www.broadcastbaron.com/bottomsaleframenew8.htm (they got 3 left for 1000$ !) http://www.productionhub.com/equipme....asp?item=4128 |
I've seen this unit already, earlier on in my research into the subject, but found it to be a bit too much. For about $1500 + or -, I can get the Firestore Pro with the 80 gig drive! You certainly got a bargain, getting two of them for $1200! :) But then, for about $100 more, I can get the Firstore base model with the same hard-drive capacity... Thanks for your input, Giroud... Bill |
(they got 3 left for 1000$ !) do not know if the three items are still there, but for 1000$ it is really a good business. The size is probably the same as the FS-4 with an optional pack that allow to mount the drive on the back of many camera (DSR serie for example). for info i "upgraded" mine with a 100$ 80gig drive and it works well (except for the counter that shows 12 hours of video when only 6 are available). You can find this kind of device on the back of an HD F900 (with miranda converter HD-SDI to DV) for pre-view in very high professional setup. And you will find no forum dealing with problems about this device.... Only regrets, it does not handle HDV. |
The great thing about the nNovia is it has analog inputs as well as 1394 as I recall. That means you can use it to capture DV with analog cameras. A very nice feature.
Sean McHenry |
| All times are GMT -6. The time now is 07:26 AM. |
