Why 2.5K?
I have seen the advantage of 4K as there are now affordable 4K TV's and the price will come down with time.
But what is the advantage of 2.5K? I don't see any 2.5K TV's on the market. |
Re: Why 2.5K?
If my maths is correct (which it probably isn't, but you get the idea), you could zoom in by 50% and still have a 1280x720 frame, suitable for web upload. It gives you the ability to mimic camera zooms/pans when there isn't any. |
Re: Why 2.5K?
Jody's right.
You can also mimic slider shots from a 1080p frame. |
Re: Why 2.5K?
Any other benefits to shooting 2K or 2.5K besides cropping and sliding?
Re: Why 2.5K?
What you get when you take a beyer sensor and add an anti-aliasing filter, is a sensor that can give you around 70% of your 1080 resolution once it's been de-beyered. So your 1080 source file can only resolve around 750 lines of actual image information. To make customers happier, manufacturers try to get 900-1000 lines of resolution from their single sensor 1080 cameras. The easiest way to do this is to increase the internal resolution to, you guessed it, 2.2k+. Most of them just don't expose that 2.2k+ resolution to you. |
Re: Why 2.5K?
Bruce,
Thank you for your helpful reply. The reason I am asking this question is that I am thinking about getting the Odyssey 7Q for my Sony FS700. I shoot mostly landscape videos and want to get the best resolution, color and dynamic range that I can. I was hoping that the 7Q could record 4K, but Sony has not granted them a license. Is the usual method in post to edit in 2K and then downrez to 1080P? Or do you downrez first and then edit in 108-P? Can you see the difference on a 55" or larger screen? |
Re: Why 2.5K?
Re: Why 2.5K?
The size of the screen has nothing to do with the resolution - a 1080P screen is still a 1080P screen. It really comes down to whether your source resolution is really 1080P or not... some cameras cannot resolve the full 1080 lines. The other advantage to the upgrade which you should consider carefully as a landscape videographer is that 2.5K raw gives you an enormous amount of latitude. You get a bump in latitude just by doing the version 3.0 upgrade with Sony because that gives you access to S LOG2. I'm pretty sure you can record that to the internal cards, but recording externally to RAW will give you maybe 6 more stops..read Adam Wilts and Art Adams articles on this forum. Remember more latitude less blown highlights and more shadow detail. But usually much more correction in post using something like Davinci Resolve. |
Re: Why 2.5K?
John,
Thanks for clearing things up for me. Do you edit in 2.5K or 2K and then down rez to 1080P for distribution and display? |
Re: Why 2.5K?
I do a fair bit of green screen work so the 2.5K raw or even 10bit compressed would give me a lot more color resolution than the current setup. That would be my main reason for getting something like a 7Q.. |
