Burning HD-DVDs @1080i Using DVD SP 4.1.2
I have been experimenting with burning 1080i60 and 1080p30 HDV footage to DVD-R discs and thought I would post my results and work flow. I have found that it is possible to burn progressive HD-DVDs @ 1080p provided you use 1080p30 footage (DVD SP does not seem to import 1080p24 footage). Both the 1080i60 HD-DVDs and 1080p30 HD-DVDs I have created have played perfectly on my Toshiba HD-A20 HD-DVD player. As expected the 1080i60 HD-DVD is interlaced, but the 1080p30 HD-DVD appears to actually be progressive.
Work Flow: 1) Export your 1080i60 or 1080p30 sequence from Final Cut 5.1.4 as a Quicktime Movie to your hard drive (You can edit 1080p30 footage in a 1080i60 timeline without having to render the sequence). Leave "Setting" at "Current Settings", check "Make Movie Self-Contained", and click "Export". 2) Start DVD Studio Pro 4.1.2 and open the "Preferences". Under the "Project" tab set the "DVD Standard" to "HD-DVD", and the "Video Standard" to "NTSC". Click on the "General" tab, and under "HD-DVD Menus, Tracks, and Slideshows", set the "Resolution" to "1920 x 1080i", the "Display Mode" to "16:9 Letterbox", and apply these settings. Note: You can also change the "Video Standard" of your SD Project from SD-DVD to HD-DVD in the "Disc Inspector" window without opening the "Preferences". 4) Next, "Import" your 1080i60 or 1080p30 Quicktime Movie into the "Assets" window of DVD SP. The Quicktime Movie will usually take a few seconds to load and then a green light appears under the "Status" column. 6) Now simply place the imported sequence into the "Track Editor" window, add your menus, buttons, etc. to your project, and you are ready to burn. Hugh |
| All times are GMT -6. The time now is 07:56 PM. |
