Please help ASAP, exporting FCP and DVD studio pro
I have always used Premiere pro and encore to make my movies in the past, this time I'm on a mac and I'm trying to figure out how I would go about making the DvD. In Premiere I would export the sequence uncompressed and then let Encore compress it to Mpeg 2 or whatever
I recently finished my movie in FCP. and I need to know the best way to get the best quality on dvd without compressing too much ect... The movie is under an hour and is ready to be exported. what settings do I use? should I export it as mpeg 2 out of FCP? If not then what? Whats the best way to get my movie into DVD studio pro and then onto DVD without losing quality. Thank you very very much -Clayton Woodley |
What version of FCS are you working with?
This is a pretty big question btw. Start playing with both apps and reading manuals. It's easy if you just put your mind to it instead of posting here for a step by step because you're lazy. Basically... - Export to compressor and start with a DVD preset. export 2 separate files, video and audio. - Import those two files into DVD studio pro and start slapping your dvd menu's together. I'm not about to get into how to use either application. - Build. 3 easy steps. |
3 Even easier steps:
Export a QT Reference movie from FCP (Export > QuickTime Movie w/ Current Settings, Make Self Contained unchecked) Import that into DVDSP ... add menu's to taste Build |
hey I figured out what my problem was. I didnt change the bit rate since the movie was only 45mins
and its not because I was "lazy" it's because I needed the information fast, couldnt find it on the internet, and didnt have the manuals in front of me. |
too late ... once a "lazy" always a "lazy" ... its on your permanent record now mate <grin>
Either way I'm glad you got to the bottom of it. |
| All times are GMT -6. The time now is 07:41 PM. |
