C/D and DVD Label Installer
Anyone know of a machine that will take a preprinted C/D label and apply it to the C/D?
Thanks! Ron |
You really ought to take a look at using printable media and getting a printer that prints directly on it.
Mine is getting a little old now, but the Epson Stylus Photo R300 really does a nice job and it was inexpensive. I have never seen a label application machine. |
Yup. I've been using an Epson R200 for over a year and REALLY love it.
No messed up labels. No bubbles on the disc. Just hit "print" and forget it. Sooooooo much more professional looking. |
Ditto - one thing I've noticed though - with the included software (R300) just one notch up or down in saturation will turn solid color into pastel, or vice versa - it's obvious that printable disks don't "soak up" ink like most papers :=) Steve
-gb- |
I have found that printing on the R300 takes about the same amount of time as making a copy of the disk. So I just move from the recorder to the printer over and over again. It isn't that hard to click on the Print button.
Labels might have a glossier fancy finish, but I seriously doubt that I would ever take the chance with paper labels again. |
I use Phillips and Taiyo-Yuden inkjet-printable discs (both white and silver) with zero problems and they are not expensive.... www.supermediastore.com is where I get my discs and inkjet cartridges - and their carts are MUCH cheaper than Epsons with great quality. |
Well, the truth is Epson did think of multiple copies, just not thoroughly! You can set the printing for multiple copies, but you can't change the disk fast enough to keep from getting an error message. So it is much easier to do one at a time to avoid clearing the errors and I can do them very fast by now. Did about 80 disks just a couple of weeks ago. Went great! I use cartridges bought on ebay, and printing 80+ used less than 1/3 of each cartridge. I was getting close to running out of ink in a set of Epson’s, so I bought some aftermarket brand on ebay for a very reasonable price. I was printing when the genuines ran low, so I switched. The printer software said, “These are not Epson cartridges!” I hit OK, and continued. I could not tell any difference in the printing, except that the after markets seemed to last longer. Used to have a CD label installer called a CD Stomper, but I just tossed it out about 8 months ago. Sorry! Mike |
Volumn
I have an Epson to make short runs.
Is there a high volumn unit out there to print large jobs? |
Depends on the speed you need - I've been looking at an all-in-one robotic from Rimage, costs about $1400 - you stack 25 disks, load your art and disk files into the modest computer needed with the unit, push the button and go do something else while it burns, tests, rejects failures and prints the good ones.
http://www.videoguys.com/rimage.html This is a lower price, it was $1900 a month ago. B&H had a couple of good reviews on their site but they're out of stock and out of sponsorship these days. Here's the manual for it - http://www.rimage.com/DAM_public/5966.pdf But nowhere do they tell what the speed of operation is. I've not yet contacted Rimage directly to ask that question. So far I've not been doing enough volume to warrant the expense, I've been using an R300 and R1800 (wide carriage, gloss coat in addition to 7 color) and haven't gotten around to throwing away my "stomper", but let's just say there's quite a bit of dust on it :=) HTH... Steve |
Allen W |
I'm surprised nobody has said this already, but labels tend to mess up discs, the balance gets thrown off and you end up with unplayable discs sometimes. I'd stay far, far away from labeling.
When you need to make 25 copies at a time Ignore the error message that appears after each and every copy and simply hit the flashing red middle light on the printer and it starts making the next copy instantly. |
I've been using the R300 for about a year now too and just recently started using the Taiyo Yuden Watershield DVDs. Man do they look good. Sure beats the heck out of spraying with Krylon!
