-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   dvd conversion (https://www.dvinfo.net/forum/dvd-authoring/60017-dvd-conversion.html)
Dante Waters February 6th, 2006 10:41 AM
dvd conversion
Ok working part time at a local church...
Seems the majority of the editing is on DVD, now I have the daunting task
of ripping about 200+ dvds back to the powermac and into finalcut for edits.
Should I just use Handbrake to rip and encode?
There are also 2 Dell systems with 3gigs of ram in each.
Should I use dvdshrink on one while I edit on the powermac?
Does anyone have an alternative?
John C. Chu February 6th, 2006 01:01 PM
From a lay-persons perspective....
If super high, "close to original quality" isn't a big concern...you could just play the DVD's and recapture it via firewire using an analog to DV converter[or via camcorder's pass thru connection]. You can then edit right away.
Obviously a quality hit right? But would take less time as the capture will be in real time.
Otherwise, the free MPEG Streamclip software works pretty good--you just grab only the sections you want from each dvd.
