-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   is my film too short for dvd player to read? (https://www.dvinfo.net/forum/dvd-authoring/50685-my-film-too-short-dvd-player-read.html)
Kevin McNerney September 7th, 2005 02:00 PM
I've just burned a dvd of a 4 minute film without a menu. It won't play in my neighbor's dvd player, but plays in my computer fine. Trying to troubleshoot the problem. I seem to recall something about dvd players not being able to read really short films on the disk. Is this true, and if so what can I do about it? Also my burner is 8x, should I try to burn at slower speed, if so how do I do that? Anything else I should think about? Thanks!
Using Maxell dvd-r, which according to videohelp is compatible with a Pioneer dv250 player. Vegas and DVD Architect.
Kevin McNerney September 7th, 2005 02:03 PM
Also... I burned the dvd using recommended standard settings, like 6,000,000 cbr.
Emre Safak September 7th, 2005 02:11 PM
Maybe the DVD player does not like DVD-Rs. See if you can bit set the disc to DVD-ROM (to make it appear like a pressed disc).
Christopher Lefchik September 7th, 2005 02:50 PM
It could be a number of things.
1. I've heard that sometimes DVD players don't like DVDs without menus. You could try adding a menu.
2. Yes, you could try burning at a slower speed.
3. It could be the DVD you used. You could try a different brand/format.
4. As you mentioned, some DVD players don't like DVDs that don't have enough content on them. Some DVD authoring/burning software can add filler to the disk so that the DVD will play.
5. Or who knows, it could be something else...
Chris Colin Swanson September 7th, 2005 03:59 PM
As the last Chris said already it could be a number of things. For your question I think his point #4 is the trouble shooting tip. Just add time to it in any form.
Many DVD players are finicky. Have you tried it in other players besides your computer and your friends player? Some media work better in some players than others. Have you played other dvds you burned in your friends player before? The more specific you are the more specific this community can answer you.
Boyd Ostroff September 7th, 2005 04:21 PM
You might see if the DVD player in question is on this list:
http://www.customflix.com/Customer/Compatibility.jsp
Kevin McNerney September 7th, 2005 05:51 PM
Thanks for the responses. This is the 1st dvd I've burned... ever. So with that in mind....
As I said, according to videohelp, this particular player should have no problem with dvd-r. I realize that's no guarantee, but I suspect the problem is something else.
So just add some black after the credits to lengthen it? Any idea how much extra time I need? Like what's the minimum length that should work, if anyone has experience with this? I mean, sure I could add an hour, but then I'm looking at hours of rendering for a 4 minute movie.
Meanwhile, I'll try some of the other suggestions as well.... THANKS!
Christopher Lefchik September 7th, 2005 09:15 PM
For highest compatibility you need at least 1 GB of data on the DVD. I don't know if matters what kind of data it is.
Dan Euritt September 8th, 2005 10:57 AM
what brand of burner did you use? is the dvd-r made-in-japan maxell? there is a lot of phony maxell out there right now.
are there both audio and video directories at the root of the disc? that can be an issue for some players.
George Ellis September 8th, 2005 12:37 PM
Did you use Nero to create the disc? Nero has a bug with files under 8 minutes. It will burn the lead-out across the whole disc and not stop.
Having had problems like this before, for really shorts, I had other footage. You could put a hard return before it and not have it linked on the menu if your software allows.
Benjamin Durin September 9th, 2005 01:51 AM
I frequently use Nero to burn 5 min DVD and when it has finished to burn the files it spends some time doing something about high-compatibility borders.
An upgrade of your software could solve the problem maybe ?
Emre Safak September 9th, 2005 06:16 AM
This is something we should know about... has it been resolved yet? I am using version 6.6.
George Ellis September 9th, 2005 06:35 AM
Nope. Fragged one this week. Actually have to power off the computer to regain control of the drive. The disc will still play in my settop, but I will not even guess that it is compatible. I only use Nero writing an ISO to -R media on a Pioneer 107.
Benjamin Durin September 9th, 2005 08:58 AM
Reading my message again, it seems I forgot to say that my DVDs play well anywhere as I give the DVDs to clients and none have complained.
I just checked and my Nero is 6.3. So I am not up to date myself ! ;)
Kevin McNerney September 9th, 2005 11:58 AM
Okay, here's where I'm at. Burned another disk with a menu and 30 min of black at the end, over 1 gig of data, and it still won't play in my neighbor's pioneer. But I took this dvd to the store and tried it in several other players, and it played fine in all of them. I'm trying to burn another one at 2x instead of 8x, see if that one plays in the pioneer player.
BUT NOW I"VE GOT ANOTHER PROBLEM!
Using DVD Architect, when preparing to burn I now get this error:
"there is not enough space in the temporary file folder for preparing the dvd"
What is this talking about? The prepare folder, or some other temp folder that DVD architect uses? There is plenty of room on my hard drive, I tried putting a prepare folder in D which has 3.5 gigs free, and then in F which has 80 gigs. C has about 3 gigs free space, fwiw. These are partioned on one drive, btw. I also did a search for temp folders on my computer, and didn't find any with huge amounts of data to delete. So I'm baffled as to what's going on here. My project size is now 1.9 gig, since I also rendered to higher quality, 8,000,000 cbr.
Also, related to using Vegas, when I rendered this one, I ended up with a .mv2 file instead of mpg. What's the difference? Or maybe this is a question for the Vegas board, but I mention it here in case it has relevance to my other problem.
Benjamin Durin September 9th, 2005 11:17 PM
The .mv2 file is video only. It should be accompanied by a file with the same name and the extension .wav.
It just means the video and sound are on separated files. But it is a normal procedure.
Kevin McNerney September 12th, 2005 12:38 PM
Update. Well, even burning at 2x (the slowest setting) the dvd-r still won't play in my neighbor's pioneer player, even though it plays fine in every other player I've tried.
Also discovered that rendering solid black after the credits only takes a faction of the time compared to rendering video.
And I solved the temp file error by freeing up more space on C drive, though I never did find exactly where these temp file folders were.
Thanks for all the advice and tips, I think I'm starting to get the hang of dvd burning now.
George Ellis September 14th, 2005 05:26 AM
Try looking up that Pioneer here http://www.videohelp.com/dvdplayers
Enter Pioneer and the model number or search through the results. Anything struck out means that a respondant could not get that media to work in that player. Light Grey either means not tested on inconclusive.
