building subtitle selection in menu under DVD studio Pro
Hi,
I am building a subtitle function in my DVD under DVD studio Pro.I got the subtitle ready and type into the DVD menu, it works fine. One problem I have is the subtitle selection on the DVD menu. At the moment, I've got 3 buttons on my menu, Play, subtitle on and Subtitle off. I was able to turn on and off the subtitle with those two button, but when I try it on a real DVD player, after I selected the subtitle on button, the selection tab was gone! I can't do anything with my DVD remote but only the menu button works...which means I have to reload the menu to gain control again.... So I went back to DVD studio Pro and discovered the button have no target, that's why the selection tab was gone. I wanted the selection tab goes to "play" button after I pressed the subtitle so I set the target to Menu 1:Button 1. However, when I pressed the subtitle button, the whole menu reloaded and went to button 1 location... I don't want the menu to reload every time I change the subtitle setting... Is there any way in DVD studio Pro to move the selection tab to another button within the menu without reload the whole menu? |
Your DVD does exactly what you 'told' it to do.
Instead of directing it to a button (which is part of the menu), you have to select the timeline as target. |
"select the timeline"?
Do I need to set the target to the track? is that what you mean? |
Probably so - I am not familiar with the Studio Pro terminology. In Adobe Encore it's called timeline - where you lay your audio, video, and subtitle tracks.
that would be the track...that's the temporary solution for me as well....
still looking for a way around it. thx! |
| All times are GMT -6. The time now is 10:44 PM. |
