-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   changing default highlighted button in DVDA (https://www.dvinfo.net/forum/dvd-authoring/467342-changing-default-highlighted-button-dvda.html)
Jamie Roberts November 8th, 2009 07:24 PM
Hi there
I have a DVD menu with a movie file button and a sub menu button.
It seems DVDA defaults to the sub menu as the one it highlights when the menu comes up.
Ive also noticed that DVD usually defaults to the 'back' or 'home' buttons in sub menu's.
How can I change which button is highlighted when a menu is opened (including the root menu).
Cheers
Jamie
Brett Griffin November 9th, 2009 12:11 AM
Jamie.
I don't used DVD Architect but in Encore, you have to change the buttons value to 'button 1' to have it highlighted first. I can only assume ( I know, never assume ) that DVDA is the same.
Don Bloom November 9th, 2009 06:48 AM
go into the Project properties, move the link of the play all button to be above the scene selection button. Now it will default to the play movie button.
Do the same in the scene selection menu in the project properties. takes about 30 seconds and you're done.
Jamie Roberts November 9th, 2009 03:26 PM
Thanks guys!
I will give it a go
Cheers
