Oliver Darden |
October 12th, 2009 11:41 AM |
Originally Posted by Ervin Farkas
(Post 1430000)
Replication is making what you call "real" DVDs called "pressed" DVDs. That's where the glass master comes in the picture - the duplication house first makes a glass master, then using this glass master they press copies on special machines. This is how the DVDs you buy in stores are made.
Ervin, thanks for all the info, got it. The DVDs we thinking about getting done from discmakers are definitely replicated.
Originally Posted by Mark Williams
(Post 1430000)
Let us know how it goes and if I can be of further help.
For sure Mark, I am dealing with the interlacing issues right now. I think I need to export out of Vegas to an NTSC DV instead of an uncompressed AVI. Everyone seems to have problems with the uncompressed AVI file. From there I am hoping they can work with the interlacing issues if need be. Maybe compressor using some deinterlacing plug in could fix this.
Originally Posted by Anton Strauss
(Post 1430000)
the DVD standard requires interlaced footage and it should be upper field first
otherwise some older players will create flicker during pans and tilts
whoever did the mpeg encoding and authoring should have corrected that, so this is not your fault
Sometimes the DVD even SHAKES when the viewer pauses the DVD player.....this is such a nightmare.....=(
Originally Posted by Benjamin Hill
(Post 1430000)
Seems like a replication house should have a more industrial strength encoding process than a Mac with Compressor, shouldn't they? If you are looking for an alternative a good reliable source is CD Technical (CD DVD Replication : Disk Duplication : CD Rom Replication : DVD Duplication Services Iowa : CDTechnical.com)
discmakers says they use real hardware compressors so well see.
