DVD-R or DVD+R -- Which is here to stay?
Hi "Guys",
I'm shopping for a DVD player/recorder to use with my television. Which media looks like it will be here to stay? DVD-R(W) or DVD+R(W) Or don't we know yet? I've searched the net, but haven't gotten any real answers to this question... Thanks for your suggestions... Dan |
As far as I can tell... neither! Everybody's arguing about HD-DVD and Blue-Ray now! Surely you can find one that will record both can't you? DVD- seems to be most compatible with other players but it's not the rule.
Yes, they are both here to stay. This debate is already settled and didn't end in a clear winner and I don't believe Blue-Ray or HD-DVD will either.
Almost all settop recorders use only DVD+R. There are a few out now that do use DVD-R, but not many. DVD-R runs ~92% compatibility rate with other players. DVD+R runs ~85%. However, since the + burners are much more available therefore cheaper - and unless maximum compatibility with other players is required - a DVD+R burner will work just fine. |
I'd like a DVD recorder which I can input my digital video via
firewire. Any suggestions for one at a reasonable price? Thanks again, Dan |
I bought an Ilo DVDR04 from walmart for $138.
After updating the newest firmware available from their website - it has worked great. I've probably ran about 30 discs through it this week alone. I would recommend you take a look at it. |
DVD Compatibility
Look for compatibility here: VideoHelp.
Really good resource, bookmark it because within the next six-months I'll bet you'll want to revisit it. The thing that burns me up is that while the trend in set-top players is compatibility with both -R and +R, the trend in off the shelf computers is exactly the opposite; its one or the other. And why are the highest priced set-tops (Onkyo) the least compatible? |
As a rule, I don't shop at WalMart, but if I can purchase that same machine
somewhere else, I might consider it. Thanks! |
Sure, I just purchased this one because even after looking around online I hadn't found any with a cheaper price. Plus there were some pretty encouragin reviews on this one.
This Ilo is just a rebadged version of some Lite-On DVD burner out there. A quick search should pull it up for you. Also, I'm pretty sure any other brand should serve you well. Just run a quick google search before you purchase it to make sure. |
thanks, I'll have to check that out.
when the new HD DVD's come out, will this take a special recorder and/or player? And will movies be distributed in this format? |
DVD-R
People who don't know - but do know about CD-R burning - will get DVD-R rather than +R mainly because the + character is different. There are no CD+Rs. I have asked people this same thing before (in a fact-finding / non accusatory way obviously) and I've heard this repeated about a dozen and a half times. |
| All times are GMT -6. The time now is 05:33 AM. |
