-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   build a stand alone dvd duplicator (https://www.dvinfo.net/forum/dvd-authoring/39461-build-stand-alone-dvd-duplicator.html)
Andrew Cleary February 14th, 2005 03:03 PM
im looking to build a stand alone dvd dulicatior, anyone know how?
Rob Lohman February 16th, 2005 04:51 AM
I'd say the only way is to put them into a computer. Otherwise you
will need to get a professional duplicator (no idea on price).
John McManimie February 16th, 2005 01:13 PM
Do you want to duplicate one-to-one or one-to-many?
Do you require labeling or will this be done manually?
You can get one to one duplicators for $250-$300. I have two DigiCopiers (http://www.addonics.com) that function as both a single USB 2.0 Burners and a one to one DVD+/-R/RW Standalones.
You can also purchase one-to-many duplicators that can range from fairly expensive to very expensive (examples at: http://www.aleratec.com/ and http://www.microboards.com/dvdduplicators.htm)
You can also get kits to add your own drives to (search Google for DVD duplicator kit).
The problem with trying to build your own is that it needs a controller (you can buy these... but that is probably more hassle than it's worth).
You can also slip a couple drives into a computer and dedicate it to that task.
Be aware that if you have added copy protection to your DVDs, the duplicators may not be able to copy them.
John
