-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   Shooting for 16:9 Mpeg2 DVD output..? (https://www.dvinfo.net/forum/dvd-authoring/38725-shooting-16-9-mpeg2-dvd-output.html)
Scott Shama February 1st, 2005 05:06 PM
How much am I gaining by buying a camera that shoots "true" 16:9 like the pana GS400, Optura XI or PDX 10 over getting a sub $2k camera that shoots great 4:3 and cropping it in Final Cut Pro?
Thanks for any advice in advance!
Cheers,
Scott
Joshua Provost February 1st, 2005 05:39 PM
True 16:9 gets you ~80 more lines of vertical resolution in your image. With the low resolution of SD, every line is important. GS400 or Optura Xi aren't that expensive, around $1000.
Scott Shama February 1st, 2005 05:48 PM
Jochua,
I have to admit that I really am interested in buying the GS400 but I am scared to death at this point of getting one with the dreaded tape transport problem... Also, where did you see them for $1k?
Cheers,
Scott
Scott Shama February 1st, 2005 06:30 PM
Sorry I mispelled your name.
Scott
Joshua Provost February 2nd, 2005 11:12 AM
Scott, no problem. I think I may have the noise myself, but it doesn't really matter unless you use the internal mic. I go with an external mic full time. There is a known fix to the problem, and the Panasonic service centers are aware of it. Takes a few minutes to fix, and it's under warranty.
Around $1000. I paid $1200 for mine from buydig.com. The Optura is just under $1000, I think.
