-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   Progressive Scan DVD questions (https://www.dvinfo.net/forum/dvd-authoring/29740-progressive-scan-dvd-questions.html)
Morgan Preston July 28th, 2004 03:35 PM
I have been getting decent results with the Lumiere capture process but cannot seem to get very good results with a final product on dvd. anyone have any suggestions as far as what codec to use as a final product for progressive scan dvds.
Graham Hickling July 28th, 2004 09:40 PM
You dont really have any option regarding what "codec" to use: the DVD specification requires mpeg2 with a max bitrate of around 9000kb/s.
Or are you asking for a recommendation for a good "encoder" to produce that mpeg? If so, Mainconcept, Procoder and CCE (google for them) all produce high-quality mpeg2 encoders.
Bryan Suthard July 29th, 2004 01:49 PM
Compressor
Morgan,
I have been getting good results using the presets in Apple Compressor to create the high quality progressive DVD output.
Rob Lohman August 3rd, 2004 07:35 AM
Progressive scan is an option on the better quality DVD players
and needs a matching progressive scan display device for best
results. Ofcourse this only works if your footage is 24/25/30p
and not interlaced. DVD format basically doesn't care.
