-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   Need help with converting DV to DVD (https://www.dvinfo.net/forum/dvd-authoring/2821-need-help-converting-dv-dvd.html)
Aaron Koolen July 23rd, 2002 04:16 PM
Hey all, a friend of mine has some DV footage (PAL) that he wants to put on a DVD. He's been playing around with TMPGENC but hasn't had good results. There are lots and lots of artifacts and the only way he's been able to remove them is to deinterlace before converting - which he doesn't really want to do cause it should be interlaced for best quality. Can someone give me some hints or suggestions of what to try with TMPGENC or the name of a good piece of software that will encode DV into mpg2 for dvd distribution.
Cheers
Aaron
Ken Tanaka July 23rd, 2002 07:35 PM
Mac or PC? On a Mac it's a cinch. PC is a different, and rather more complex, story.
Aaron Koolen July 24th, 2002 01:21 AM
Oops, sorry about that. He is using a PC.
Rob Lohman July 24th, 2002 04:50 AM
TMPGEnc should be able to yield very good results. Make sure you
tell the encoder whether the source is interlaced or not! What
settings where you using? Constant bitrate? Variable bitrate (how
many passes?). What bitrate settings etc. ? I can try with my
version to see what yields good results for me (i'm not using
interlaced though).
Aaron Koolen July 24th, 2002 06:24 AM
Ok Rob, I'll ask him of all the details and post them here. If you could give it a try with that it'd be a great help. Even with a little bit of interlaced footage of a medium speed pan will shotw horrendous results.
Cheers
Aaron
Edward Troxel July 25th, 2002 12:00 PM
Tell him to follow the formula presented at this website:
http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
Aaron Koolen July 25th, 2002 01:49 PM
Thanks a heap Edward - I'll pass that link on to him
Cheers
