-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   Anamorphic DVD Menu? (https://www.dvinfo.net/forum/dvd-authoring/21602-anamorphic-dvd-menu.html)
Jack Robertson February 18th, 2004 10:56 PM
Hi all,
Working in PAL, I know the frame size is 720 x 576 pixels for creating 4 x 3 menus, but if I was to create a menu which was 16 x 9 (anamorphic) what size would the menu have to be?
Or would the frame technically still be the same size, but squeezed in someway?
Any info would help.
Cheers,
Jack
Rob Lohman February 19th, 2004 05:59 AM
I think you are confusing a couple of things here. The *FINAL*
framesize (for PAL) will ALWAYS be 720x576. Whether or not the
input is 4x3 or 16x9.
To get a correct 4x3 image to use for a menu you would import
a 768x576 (1.067 PA) or 786x576 (1.0926 PA) image (depending
on which pixel aspect you find matches closest) into the
authoring package or if it wants the final size create the image at
that resolution and then resample it down to 720x576 (without
maintaining aspect ratio!) before importing.
Now with widescreen you have a pixel aspect of 1.4568 (according
to Vegas -> the NLE I'm using. Other NLE's are probably using
a slightly different number). So that would mean that a picture
at 1.0 pixel aspect should be 1049x576. Import that into your
authoring package or resample it down to 720x576 (without
maintaining aspect ratio again) and import that.
This should do the trick.
Julian Luttrell February 19th, 2004 07:31 AM
Rob,
Vegas' calculator seems a little off - square pixel 16x9 PAL corresponds to 1024 x 576 (1024 divided by 576 = 16 divided by 9, see?).
Julian
Rob Lohman February 20th, 2004 05:49 AM
Julian: I know that's what all the other packages are using. In
other words, they are using a 1.422 PA for widescreen PAL. So
720 x 1.422 = 1024 as well. Vegas is using different numbers.
I've done a little bit of research and it looks like Vegas is using
the original numbers as it was meant to be. Therefor they also
claim they are the only one using the correct numbers. I found
something that seems to conform this claim, but everybody else
So that's a bit of a "weird" thing. As said in my previous post,
the numbers that I used came from Vegas. If you are using a
different package stick to 1024x576 indeed.
Jack Robertson February 20th, 2004 06:19 AM
That explains it!
Thanx for the tips guys, I knew there had to be a slight catch and a mathematical explanation for this.
I'll do some testing and see how it all looks. In my case I use Photoshop/Premiere/AE to edit and TMPGEnc to encode, I haven't really settled on an Authoring package, but I might try out Encore DVD.
Cheers,
Jack
Julian Luttrell February 20th, 2004 06:50 AM
D!/DV and PAL/NTSC
Rob,
at the risk of being a techie bore...
Vegas' figures for PAL wide screen pixel aspect ratio of 1.4568 means they think there are 704 x 576 PAL 16:9 pixels in a widescreen frame. This is wrong.
[maths: each pixel is 1.4568 times wider than it is high, so a 16:9 image consisting of 576 lines will be w pixels wide where: 1.4568 x w / 576 = 16 / 9. This gives w = 703 (or 704 allowing for rounding errors)]
This strange 704 number actually originates from the NTSC world, where (for some reasons better known to those who are never the same colour) they have TWO different standard definition digital frame sizes: 704x480 and 720x480. I never worked out when each is used, but there you go.
PAL doesn't have the same problem.
Your 1049 number comes from multiplying the 704 pixel aspect ratio by 720 - a mistake I'm afraid.
The size to use is easy to calculate without EVER getting involved in pixel aspect ratios!
With square pixels as used in Photoshop (until recently), the ratio of the number of pixels across to the number of pixels down must be the same as the ratio of the frame width to frame height (=16 by 9). So w / 576 = 16 / 9 giving w = 1024.
Regards,
Julian
Rob Lohman February 20th, 2004 06:54 AM
We are on the same line here Julian. I don't understand either.
But when I brough it up sometime earlier it was claimed that it
was correct and everybody else was wrong and I was challenged
to prove this (that will be very hard to do, since all the numbers
are based on others).
I just gave the calculations based on numbers I found in the
NLE (and in my second post also for the rest of the NLE's).
Even the numbers for NTSC are off in Vegas from the rest of the
world!
