Record direct to DVD
Is there a way to record directly to a DVD via a firewire using a PD 170 or Z1?
I gone to DVD direct numerous times with 170s/250s BUT not thru firewire. The DVD burners i have don't have FW capabilityso I used S video and composite audio. Works great for seminars. Just a note to add though, most times when I go straight back to DVD I use a small DA and run 2 machinces. That way I have a backup just in case. Generally the events I have done straight to DVD never run more than 1 1/2 hours or so without a break but watch your time.
I've used FW out of a Sony PD150 to go direct into FW In on a Panasonic DVD recorder with no issues.
sure...you just have to find a stand-alone DVD burner with firewire input. I have an old Sony RDR-GX7 and I go firewire directly in from my avid, dvcam deck and canon XL1.
I know the TV top dvd recorders will work, but I wonder if there is something a little more portable (smaller)?
I've used a Toshiba DR-400 to record from a GL2's firewire out, worked great.
Note that many of the panasonic dvd recorders get a bad rep for picture quality, especially recording in 4 hour mode. You can see a list of ratings of recorders with firewire at DVD Recorder and Blu-ray Recorder list Note that just because a DVD recorder has a FW port doesn't mean it will take FW output from a PC. My Toshiba only assured it would work with a camcorder. --Shayne Weyker |
Thanks Shayne...I'll check out that website.
Bill, you also might want to check these threads already in progress
http://www.dvinfo.net/conf/dvd-web-v...burn-live.html http://www.dvinfo.net/conf/wedding-e...fly-event.html Good info on this subject in there. |
Thanks Byran....that is just what I needed.
| All times are GMT -6. The time now is 02:41 PM. |
