-   DVD Authoring (https://www.dvinfo.net/forum/dvd-authoring/)
-   -   CS3 how to put a video on the dvd (https://www.dvinfo.net/forum/dvd-authoring/129417-cs3-how-put-video-dvd.html)
Nathan Quattrini September 5th, 2008 01:44 PM
Sounded so simple but I can`t get it to work. I have a file 1440x1080 1.33 PAR in Premiere. I tried using premiere to export to Encore and burn straight to disc. Not sure really what settings I should use. The DVD burned, but plays different on every DVD player in the house. One playes a few seconds then blocks then a few seconds then blocks, etc...another plays it fine but everything is shifted to the left (I may have chosen widescreen in premiere I don't remember) and then on my computer it played fine, looked lower quality than on the tv and only had maybe 2 spots where it glitched with blocks.
How should I go about this? It doesn`t seem it should be hard. Video in premiere just needs to go on a DVD for a local film festival.
Mike Gunter September 5th, 2008 02:35 PM
Hi,
It sounds like you can just File>Export>Export to Encore>Settings
Which will bring up the Adobe Media Export Settings.
Depending upon the length of your show, you probably could just take the default settings.
NTSC Widescreen, Medium Quality (I wouldn't be too concerned about Medium/High)
720x480
29.97
48KHz, 16bit, PCM
7.00Mbps VBR, 1Pass, Target 4.00
Quality 3
You can tinker with the settings, even use a Progressive Widescreen, too, depending upon your goals.
My best,
Mike
Chris Light September 5th, 2008 11:33 PM
is 720x480 going to make for a good looking dvd?...ive been keeping all of my projects at the full 1440x1080, and they look like crap on dvd....maybe thats becuse i'm using Movie Maker...i am yet to et decent advice about dvd authoring on MM until i get a better NLE
chris
Mike Gunter September 6th, 2008 12:06 AM
chris
Hi Chris,
Unless you are using Blu-ray or HDDVD (May it Rest in Peace), your output in DVD will be in NTSC will be 720x480 in an MPEG2 compatible format in either WAV or AC3 (Dolby) audio. That's the specification; it is what it is.
Making it look good is something else.
If it looks good as HDV, it should look good as DVD, assuming a good bit rate for the encoding and a good piece of software to encode it. Movie Maker isn't a particularly good choice for an NLE, but then you get what you pay for.
TMPGEnc Xpress 4.0 is good for the price for encoding and Sony Vegas is great for editing.
Good luck.
Mike
Chris Light September 6th, 2008 10:42 PM
thanks Mike...that's exactly the direction i'm heading in! but does Vegas still need a separate encoding program like the one you mention, or can it hold it's own for dvd authoring/encoding?
Mike Gunter September 8th, 2008 06:39 AM
Hi,
Sure, it can. But if you're pushing the envelop beyond two hours and still want to put content on a single layer disc, you might want to invest in an additional encoding tool.
My best,
Mike
Chris Light September 8th, 2008 10:24 PM
nah, no epics here...i do 5-10 minute short subjects...your input has been very helpful to me Mike, thank you.....love this site!
Tripp Woelfel September 10th, 2008 08:51 PM
Chris... In the interest of saving you money, if you have and like CS3, you should get good quality DVDs from Encore and the AME. TMPEGEnc is a great transcoding tool and I think there's a way to frameserve from Premier but I've never tried. By adding TMPEGEnc, you might boost your quality. It's cheaper than Vegas.
But... before you do that, try Mike's suggestions. I have authored SD DVDs from HD Premier projects with great success with none of the problems you've had. Not saying I've not had problems but they were more of a "learning-curve" nature than from the technology. I got through it and I expect that you will too. A cup of Peet's and a bucket of patience will help.
