Just burnt my first DVD- stuttering video?!
I just finished authoring and buring my first full size, complex menu DVD. Everything seemed to be fine as far as the inferface etc. The problem I found was in the video. Namely areas where there is a fast pan, or quick motion- the video looks stuttery almost the same way video looks if you slow it down and forget to reduce interlace flicker.
I encoded in Procoder @ 8000kbs CBR...which is well above the conservative 6000 average. What could be the problem?! |
It may be that because CBR applies the same data rate to all footage, regardless of motion/action, you aren't getting enough bits assigned where they're most needed. You might want to try a section with VBR set to 2000 min 8000 max, and 5-6000 average if your encoder offers all three choices. Doing a test will save you waiting for the whole project to encode before discovering that your problem is solved or not.
David Hurdon |
| All times are GMT -6. The time now is 03:48 PM. |
