Best slider under $500
Hello! We are looking for a good slider for DSLR use that is of good quality and has either a motor or a flywheel to make the movement really even. What slider would you recommend if in the less than $500 range?
It can be of about 80 cm (30"). |
Re: Best slider under $500
Shark Slider S1 works well for me.
The S1 is a great slider but is going to be closer to $650. Slides are buttery smooth with the flywheel.
looking for a good slider and found this one:
kamerar fluid motion slider. about 250 euro. I have never used a slider but maybe buying a cheap one is not a good idea. any thoughts? |
