Panasonic SD900, ClipWrap Trial, Lion
I'm very close to registering but have a niggle-
When I use the 5.1 mode of the cam and any HD recording mode, the clipwrapped file audio shows as "Mono" in QuicktimeX and plays back only FL and FR in FCPX - at the very least I'd expect the centre channel to also be active. I know I can just record in stereo on the cam, but there are instances when 5.1 may be my preferred acquisition. Any ideas? I don't know if this is Lion/FCPX/QT vs Panasonic AVCHD 2.0 issue alone, or if clipwrap can conform the files to have the channels recognised correctly in QTX and FCPX? (I'm using LPCM to clipwrap). Any help or advice appreciated! |
Re: Panasonic SD900, ClipWrap Trial, Lion
We have a special app to force 5.1 output. If you contact dmsupport@divergentmedia.com we can send it to you. It'll be rolled into a future release.
-Colin |
Thanks immensely for the quick turnaround! I will test the app shortly once work is finished here ...
Just popping back to say the special app works on my files, and thanks again.
