Clip Wrap breaks MT2 files up into 21min segments?
If this has been posted and addressed in a prior thread I apologize. I couldn't find it.
When recording continuously to the CF card for long period's of time, then using ClipWrap to ingest the file, the M2T files are broken up into 21:42:12 length clips. - AND - there are lost frames between the clips. Has anyone experienced this? When importing the same footage through FCP Log & Transfer the file comes in all together in one clip as you would expect. I don't typically record in segments longer than 21min so I never noticed this issue before. I confirmed with an colleague that also uses Clipwrap that he has the same issue. Other than this issue, I actually prefer Clip Wrap over the log & transfer process. I was just wondering if anyone else has seen this issue. Regards, -Dave Mungai |
Actually they are already broken up. Check the card and you will find that no clips are longer than 21 minutes. So clipwrap is just taking each clip off the card. I just discovered this myself.
Jerry |
Thanks, -Dave |
clipwrap doesn't put the clips together and log and transfer with fcp does. Annoying.
Jerry |
I haven't had any luck so far, but that might have been due to the fact that I wasn't shooting in cache mode on the MRC1K. Quote:
It works flawlessly with split M2T files from my direct to disk recorder which is a FireStore hard drive. However your problem might be due to a difference in file formats in CF cards or the AVCHD codec. They are probably working on it right now.
This is a known issue for ClipWrap. The sony recorder places 2gb split files in multiple folders and writes out a file which acts as a table of contents. FCP reads this file to know how to recombine them. We don't have any documents on this TOC, so we will need to reverse engineer things to make it work. In the meantime...
ClipWrap can recombine files from the sony recorder, but you'll have to do some reordering / renaming of the files to get things to work. If ClipWrap sees 2+ files in the same folder with randomfilename00.m2t , randomfilename01.m2t ... randomfilename0n.m2t , it will automatically join them. So to make it join your files, pick the name you want the output .mov to be... rename all the files to thatname00.m2t ... thatname02.m2t ... etc and put them all in the same folder. This way it will be sure to join them so you dont lose those frames in between. I hope that makes sense. mike -- Mike Woodworth mike@divergentmedia.com |
Regards, -Dave |
