-   Distribution Center (https://www.dvinfo.net/forum/distribution-center/)
-   -   DVDSP2 menu question (https://www.dvinfo.net/forum/distribution-center/26335-dvdsp2-menu-question.html)
Suzanne LaBrot May 21st, 2004 09:41 AM
Hi all,
I'm using DVDSP2 on a G5. I'm creating a fairly simple menu. 2 buttons, text only. I want the "buttons" to highlight the text only when selected. I have a strange little box that keeps highlighting or the size of the whole button. How do I set the menu so the text only highlights?
While I'm asking, how is the best way to put a picture in the button? My first instinct is to export a still image from my FCP sequence and then bring it in thru the templates. Am I on the right track?
Suz :)
Richard DuPree May 22nd, 2004 02:46 PM
Create your buttons in Photoshop. Use the "layers" function to create the same text with a second color. Import your Photoshop file into DVDSP, create your buttons there with the text from the Photoshop file. You can turn on/off the text color by turning on/off the Photoshop layer.
Ray Echevers July 8th, 2004 08:31 PM
You can also check or uncheck a box in the Button palette or menu to highlight.
