-   Distribution Center (https://www.dvinfo.net/forum/distribution-center/)
-   -   PAL to PAL-M? (https://www.dvinfo.net/forum/distribution-center/126626-pal-pal-m.html)
Luis Rolo July 24th, 2008 07:23 PM
PAL to PAL-M?
Hi everyone.
I'm in PAL land and I've been asked to make a wedding video in Brasil, but i found they use a different system called PAL-M. It seems it's PAL but 60HZ, 29,97fps and 525 lines (seems more like NTSC). See it here: http://en.wikipedia.org/wiki/PAL-M
According to that link, it's a hard conversion. Any clues how to do this?
L.R.
Tripp Woelfel July 24th, 2008 08:31 PM
Beats the snot out of me, but you may be working this the long way around.
Based upon your Wikipedia link, PAL-M is identical to NTCS except for the color carrier which won't matter for your shooting since you'll be shooting standard PAL. You could try chasing a conversion in post to PAL-M or you can try to find out what standards contemporary TVs and DVD players support in Brazil. This might be a lot easier.
From what I've read, many modern PAL TVs and DVD players also support NTSC. In the US, very few TVs and DVDs support PAL. I have no clue as to what the sets and players support in Brazil. However, I doubt the major movie studios have a DVD production line dedicated to a corner-case standard like PAL-M. More likely is that the Brazilian DVD players support the playback of another standard. My guess is NTSC, but we'll need input from our Brazilian bretheren.
If they support a conversion from standard PAL, then you're golden. If it's NTSC, it gets a bit more complex but your NLE can likely handle it.
Luis Rolo July 24th, 2008 09:39 PM
Thanks for the reply.
Hope some Brazilian step by DVINFO.
Brasileiros deste site, ajudem-me!
L.R.
Jon Fairhurst July 24th, 2008 11:39 PM
If it's on DVD, just shoot NTSC and burn a 60 Hz disc. The component output will be 525/60, which is exactly what you want. The PAL color sub-carrier encoding for the composite output will be integrated into the DVD player's hardware.
Not that I'm from Brazil, though I will travel to Sao Paolo (first time) in a few months.
If your DVD Player and TV can't handle an NTSC DVD, test the result using a software player, such as Nero or Power DVD.
Luis Rolo July 25th, 2008 08:56 AM
A Brazilian told me PAL-M is only used in broadcast, and the DVD system there is NTSC.
Can anyone confirm this?
This would be a good thing, because i assume a PAL to NTSC conversion would be much easier.
L.R.
Dan Burnap July 31st, 2008 07:15 AM
Hi, I live in brazil and can confirm its NTSC here. Shoot and burn NTSC no doubt
Luis Rolo July 31st, 2008 08:42 AM
Thanks a lot Dan. Problem solved.
