-   Distribution Center (https://www.dvinfo.net/forum/distribution-center/)
-   -   Real time mpeg2 encoding (https://www.dvinfo.net/forum/distribution-center/114758-real-time-mpeg2-encoding.html)
Ben Lynn February 13th, 2008 06:12 PM
Here's the situation: The job is very lengthy and requires the final output to be on dvd. So, rather than spend a week encoding the footage (120hrs. worth) I want to know if there are options for encoding a live stream to an mpeg2 format. A stand alone recorder would work if it wasn't for the menu systems. This dvd needs to have very nice menu's like you would build in a software solution.
Does anyone know a software encoder for real time mpeg2 encoding? It would need to encode the stream as it comes in through a firewire line. The software would be running on a laptop and recording to an external hard drive.
Thanks for the help.
Ben
Ervin Farkas February 14th, 2008 04:44 PM
The fastest mpeg2 encoder I know of is CinemaCraft, but I don't know if it can take a live stream... probably not. If you need fancy menus, you need DVD authoring software, in which case a stand-alone encoder would work just fine with the live stream - you could then rip the DVD, revert the VOB files back to mpeg2 (with Streamclip for example, no re-encoding), then author the final DVD with menus.
Ben Lynn February 14th, 2008 07:58 PM
Thanks Ervin.
I think your right and the fact that the project requires nice menus may force us to either encode the files or use a stand alone player and then pull the files off.
Ben
Robert M Wright February 15th, 2008 12:56 PM
I haven't tried it, but with a powerful enough processor, I would think you could transcode DV streaming over a firewire to MPEG 2 files (that would be compatible for DVD authoring) with VLC media player.
William Hohauser February 16th, 2008 02:31 PM
Try this method, I do and it works great.
Use a stand-alone recorder (Panasonic consumer models or JVC SR-MV30 are my picks) to capture the footage.
Get a free program like MPEGStreamclip and de-mux the DVD to a mpeg2 video file and aac (or aiff) audio file.
Import the files to a DVD authoring program that can recognize the components (I use DVD Studio Pro) and create a new DVD with some nice menus.
This method is quick, very low cost and works really well. I'm about to finish a client project right now using this method.
Ben Lynn February 17th, 2008 10:06 AM
Thanks William, that appears to be the only real-time encoding option: a stand alone recorder. Sounds good.
