Converting .mov to .wmv using Vegas
I have FCP and Vegas systems, and am now producing in FCP. I can post Quicktime movies, but a smaller percentage of people can see them. How would I best import the FCP version into Vegas to output a WMV? My tentative plan is to switch hard drives from Mac to PC and import the bigger .mov file, then render it to a small WMV.
I'm thinking that with Quicktime and WMV versions accessible I would cover 99% of viewers, and this way I wouldn't have to buy anything. Would I have a lossless conversion? Thoughts? |
Depending on file size and frequency, I would consider burning .MOV to a data DVD and transfer that way.
Another alternative (cheaper in long run) is to use a USB memory stick. It's been too long since I used a Mac (MacOS7.1, circa 1999 I believe!) so don't know the ins and outs of using DVDs and memory sticks that are compatible with both platforms, but my guess is that it's reasonably easy (I've read a few posts that suggest it is) Vegas 7 requires Quicktime seven point something (can't remember exactly - I'm using 7.1.3) in order to play nice with .MOVs. I've created a couple of .wmvs from .MOV source footage for customers successfully. Sorry - don't have samples that I can share right now (a little over-enthusiastic with HDD housekeeping a few days ago...) Regarding quality/losslessness - can't comment beyond "I was satisfied with the results." As far as actually creating the .wmv is concerned - it's just a case of sticking the .MOV in the timeline and rendering as... I'll leave it to others to suggest detailed settings for the .wmv render HTH |
Cannot Customize Quicktime Install
Thank you Reg,
Good idea with the jump drive. I just about got it to work. The only problem was that just the audio popped into the Vegas timeline. I did some checking and found that I needed to update Quicktime and customize the install to be able to edit the video. I tried uninstalling and reinstalling several times and couldn't find a way to customize the install. So I'm close. I just need to figure out how to customize the Quicktime install. Thoughts? |
| All times are GMT -6. The time now is 11:44 PM. |
