Firewire gets a speed boost
The new S3200 spec is announced and 3.2Gbps is the speed using FW-800 cables. Your direct to disk solution should do 4k now :D
http://www.informationweek.com/news/...d=nl_IWK_daily |
Nice!
Always liked Firewire much more then USB. Faster, more stable (it seems, can't really explain this), better standard (read: faster),... |
It is faster than dual HD-SDI. Interesting.
Considering that USB 2.0 tends to run at whatever speed it feels like, I'm all for improvements in Firewire.
I always thought the bottleneck was with the write speed of the storage devices...
Now if MS were to remamange the 1392 standard so as to not destroy MBRs at the drop of a hat, things would be peachy...
Single solid state drives are around 100MB/s sustained. That is 800Mb/s and you never want to be that close to max. Add a parallel array and you need more. Burst speed on some platters is above 100MB. So, it needs to go up.
That speed only matches what is already shipping for external discs: eSATA
That's awesome. Maybe that's why apple didn't add esata.
Poor Connector?
I never liked the FW800 connector because it never feels very secure when plugged in. I've used four different brands of FW800 external drives and all of them feel as if the cable will suddenly slip right out without warning. It's not happened yet, but I'd imagine it wouldn't take much of a nudge to shake the cable loose from the drive.
This isn't a big problem when you're talking about a stationary desktop system, but they're talking about this new spec being used on anything from cameras, to computers, to AV gear. I could see this being a problem. But that's just me. Anyone else feel this way or am I just wrong here? |
...the eSATA plug latches...and there is no latency with it as there is with Firewire or USB.
| All times are GMT -6. The time now is 11:34 PM. |
