New firmware release DN-60
Date: 11'01'31 Version: R111 Board: Main PCB ChipLocation: U2
Note: Bug Fix: 1. Fix NTFS file length miss calculation in NTFS directory 2. Add error handling when eject CF card in the middle of play or record 3. reduce pre-trigger record buffer to prevent buffer overflow during pre-trigger recording 4. Prevention for protential incorrect file system update when there's power failure during recording 5. Fixed occasional unexpected interrupt in the middle of make media file process 6. Fixed endless process running when execute: a. Empty Current Bin b. Upgrade Firmware without CF card inserted 7. Fixed record issue when try to record several times within same BIN with Z1 in HDV mode 8. No record pause allow when reach to 99 clips 9. Can't record to a Bin consist 99 clips 10. Fixed incorrect Quicktime essence data length ("mdate") in NTFS 11. Fixed possible signal loss when doing "Record on Power Up" New & Change: 1. Bin centric and Clip centric play modes: User can select desired play mode to play all the clips in sequence within a Bin. (Bin centric) Or play single clip at a time. (Clip centric) 2. DV Hidden Mode: This is feature made for HS-550 to avoid connectivity issue happen when connect both HS-550 and DN-60 to PC or Mac. Date: 11'01'31 Version: R11 Board: Main PCB ChipLocation: U8 Note: 1. Remove "Nimh-2" from battery type selection 2. Add menu selection for “Set Play Mode” (Bin centric or Clip centric) 3. Add menu selection for “DV Hidden Mode” (for HS-550) Datavideo Technologies Co., Ltd..Service WEB Site I have tried firmware upgrade its failed. I never had problem with older version firmware upgrade. |
I was just going to purchase one. Keep us informed if you solve the problem.
Firmware update failed for me, too. I hope this gets solved, because I really would like the "bin play" option.
Ken did the firmware update failure stop your DN-60 from working?
Unless someone can come up with a solution I will have to purchase an alternative. |
Hello there,
I just managed to update the firmware without problem. Follow the instructions as shown in the manual Copy the "DN60_v1_11_CF_upgrade.bin" file to the CF card When that is copied to the CF card then change the name of the file to "flash.bin" Insert the card into the DN-60 and go through the usual upgrade process. I tried to do it with the other .bin file (DN60_U2_v1_11_ROM.bin) but it kept on failing... I wonder why that .bin file is there??? Hope this helps Best Gavin |
I did as instruction, it is failed. Somebody from DataVideo should be give us solution.
Without clear instruction all three files to upgrade firmware not good. DN60_U2_v1_11_ROM.bin DN60_U8_v11_ROM.hex DN60_v1_11_CF_upgrade.bin I have tried DN60_v1_11_CF_upgrade.flash its failed. |
The error message comes immediately upon trying to perform the update, so it actually never starts. In my opinion, it seems the DN60 doesn't recognize the file as a legitimate firmware file. I've not yet been disappointed with my purchase of the DN60. |
you need the .bin extension for it to be seen.
I had no problems upgrading so I don't see why others are..... I agree, someone from Datavideo should chime in with an explaination |
Gavin could you explain me how do you write down the extension?
Here I have tried as instruction which I did an older version upgrade firm ware successful. DN60_v1_11_CF_upgrade.flash /bin should be replace with flash/ |
I was finally able to get the update to go through by following your steps. Thanks for the help, Gavin.
Problem is, the firmware update disables playback from the DN-60. Old clips (prior to firmware update) wouldn't play. I formatted another card and captured new clips. The new clips would not play back, either. Both bin centric and clip centric playback modes experienced the problem. Bummer. Fortunately, I was able to flash the firmware back to the previous rev. Datavideo doesn't include the DN60_v1_11_CF_upgrade.bin firmware on their official DN-60 support page, so that probably means it's not quite ready for primetime. I am anxiously awaiting a final firmware that adds bin centric playback. Hopefully, soon. |
I updated successufl. Which is not as instruction. I misunderstood Gavin explanation.
Here what I did: Copy to your CF card : DN60_v1_11_CF_upgrade.bin REPLACE flash.bin Instead of DN60_v1_11_CF_upgrade replace flash If it helps |
Ken
My old clips (prior to firmware update) played well. bin centric and clip centric playback modes properly working for me. I used SanDisk Extreme CF 60MB/s 32GB Removed "Nimh-2" from battery type selection as well. |
Maybe I'll give it another shot this weekend. I have Transcend 400x 32GB and a Pretec 567x 64GB cards. Neither one would work with playback. I tried NTFS and FAT32 with both. When I rolled the firmware back, playback worked.
Any update if the latest firmware works?
