-   Datavideo DN-xx Series Recorders (https://www.dvinfo.net/forum/datavideo-dn-xx-series-recorders/)
-   -   Nnovia vs Firestore for JVCHD110U? (https://www.dvinfo.net/forum/datavideo-dn-xx-series-recorders/115493-nnovia-vs-firestore-jvchd110u.html)
Jim Fields February 13th, 2007 03:39 PM
I have 2 Citidisc HDV 100gb drives for my JVC camera.
And I hate them, with all of my heart.
I grow tired of those wonderfull 8 minute clips, you know, the ones with dropped frames that I was told would never happen.
I also hate how after 2-3 hours the drives decide to just stop recording, even though there is plenty of power, and space on the drives.
So I am looking for a new DTD soloution. I was looking into the Firestore for my JVC camera, when I was pointed to the Nnovia QC120 for HDV.
From what I was told by the rep, the Nnovia will record say 4 hours non stop, one big file. I dont care if it is a M2T file, as I use MPEG Streamclip to convert for FCP, however a 720P30 QT file would make me even more happy.
So, the Nnovia QC120 from what I am told is the only NTFS drive soloution out there, which is where I get the non "8 minute" clips.
Is this true?
Anyone have the Nnovia, what about the firestore? how do the 2 compare.
I plan on using a AB gold mount kit to keep from using external batteries like I do with the Citidisk. How does the gold mount do for energy consumption do? will I loose say 45 minutes off of the AB batts if I go that route?. I need more details than what I was given with the CD drives.
I need some stories here, these things are not cheap and I allready spent XX amount on all that Citidisk crap as it is.
Jon Snyder February 14th, 2007 03:30 PM
Need A D2D with analog component input
Does this exist? Want to output from a switcher using analog component into a D2D to have a hard drive based recording. Looking for a least 3-4 hours...
Jon
Dave F. Nelson February 14th, 2007 05:25 PM
Jon
Try this thread. They are trying to do this while trying to avoid the more expensive HD SDI solution.
http://www.dvinfo.net/conf/showthread.php?t=86267
Hope this helps.
Giroud Francois February 15th, 2007 01:48 AM
a chasecam has analog input, but it records on compact flash not on HDD and with mpeg2 , not DV.
