-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   Firmware Update 2016.01.1336 (https://www.dvinfo.net/forum/convergent-design-odyssey/531356-firmware-update-2016-01-1336-a.html)
Dan Keaton March 8th, 2016 10:28 AM
Dear Friends,
Here are some details for the firmware update 2016.01.1336.
We continue to add features and improvements to our Odyssey and Apollo line of products.
Briefly:
The Odyssey7Q and Odyssey7Q+ are now capable of recording 4K at 50, 59.94 or 60 frames per second from video sources. The Odyssey7Q+ has more input flexibility in this regard.
HD-SDI 6G inputs have been added to all Odyssey7Q+'s.
With the Apollo or Apollo Option, one can now record two streams of 4K or Ultra-HD (UHD) up to 30 frames per second. The sources must be video and not Raw for this mode.
And with the Apollo or Apollo Option, four streams of 1080p50, 59.94 or 60 are now supported
New Apollo Features
(Apollo or Odyssey7Q or Odyssey7Q+ with Apollo Option)
Dual-4K
• Monitor & Record two 4K/UHD video signals
• Supports 4K/UHD 23.98p, 24p, 25p, 29.97p, 30p
• Record in Apple ProRes (HQ/422/LT)
• Resolution & frame rate must match
• 4K/UHD video only, no RAW conversion
_____Dual-4K Input Combinations (Apollo & Odyssey7Q+):
• HDMI + 3G-SDI Dual-Link (use SDI C & D inputs)
• HDMI + 6G-SDI (SDI B input)
• 3G-SDI Dual-Link (SDI A & B inputs) + 3G-SDI Dual-Link (SDI C & D inputs)
• 6G-SDI (SDI A input) + 3G-SDI Dual-Link (SDI C & D input)
• 6G-SDI (SDI A input) + 6G-SDI (SDI B input)
_____Dual-4K Input Combinations (Odyssey7Q):
Quad-HD 1080p 50/60 Support
• Monitor & Record up to four 1080p 50p, 59.94p, 60p video signals
• Recording of Quad-Split or Live-Switch are not available when inputs are 1080p50/59.94/60
• Both 3G level A and 3G level B supported
_____Input Combinations (Apollo & Odyssey7Q+):
• HDMI + 3x 3G-SDI
• 4x 3G-SDI
_____Input Combinations (Odyssey7Q):
• 4x 3G-SDI
4K 50/60p Support
• Monitor & Record 4K/UHD 23.98p, 24p, 25p, 29.97p, 30p, 50p, 59.94p, 60p
• 4x 3G-SDI required for 4K/UHD 50p, 59.94p, 60p
• Dual-4K not supported at 50p, 59.94p, 60p
Supporting Sony F55 & IO Industries 4KSDI
• Set F55 to “2SI” output for 4K/UHD 50p, 59.94p, 60p
• Set IO 4KSDI to Quad-Link interleaved output for 4K/UHD 50p, 59.94p, 60p
Additional Apollo Functions
• Lower Toolbar full screen switching in Quad-Split or A/B/C/D recording modes
• Improved Monitoring Tool usage when not recording
• Program-Preview single-tap switching in Live-Switch mode
(upon selection of new Program source, previous selection automatically becomes Preview)
• Input labeling (display as overlay on OLED and/or outputs)
Respectfully,
Gary Huff March 8th, 2016 10:39 AM
Re: Firmware Update 2016.01.1336
Quite a nice update, Dan.
Dan Keaton March 8th, 2016 11:16 AM
Dear Gary,
Thank you very much, it is, of course, a team effort.
We have many more features in work for future firmware releases.
Respectfully,
