-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   O7Q compressed CODEC data rates? (https://www.dvinfo.net/forum/convergent-design-odyssey/521799-o7q-compressed-codec-data-rates.html)
Paul Gale February 22nd, 2014 03:08 AM
Some questions regarding compressed HD recording with the upcoming Feb firmware:
1) When support appears for the compressed CODEC shortly, will there be options to set the recording data rate or will this be fixed?
2) Are the record times as shown on the chart on the CD website or has this changed at all?
I think my major use of my O7Q will be to record mainly HD compressed (super sampled 4k) with occasional high frame rate shots. Having the ability to select a data rate that gives me the choice of quality vs file size for a particular project is very important. Not all projects would justify the additional expense of significantly larger files over the FS700 inbuilt recording options. Some will though.
Having the choice will be great but is this the plan for the development of the compressed CODEC or not?
Thanks.
Dan Keaton February 22nd, 2014 12:07 PM
Re: O7Q compressed CODEC data rates?
Dear Paul,
For our upcoming firmware release, due out around the end of February 2014, we expect to offer:
A popular compressed codec, at 220 Mbps, in HD (1920 x 1080), 4:2:2 YCbCr, up to at 23.98, 24, 25, 29.97 and 30 frames per second., thus, up to 1080p30.
Later we will add 50, 59.94, and 60 (up to 1080p60) at a higher bit rate.
And we will add an RGB 4:4:4 version at a higher bit rate.
The approximate recording times listed on our website, for the compressed codec at 220 Mbps, are still valid as far as I know.
Respectfully,
Paul Gale February 23rd, 2014 04:35 AM
Thanks Dan,
Will you support the lower data rate (147 and 100mbps) modes too (for those projects that don't need higher quality) and also proxy mode? They would be great for the longer format projects.
Will the same options also be available for the 4k super sampled to HD mode?
Thanks.
Dan Keaton February 23rd, 2014 09:37 AM
Dear Paul,
For this upcoming firmware release, we will only support the 220 Mbps version.
We expect to support more Bit-Rate versions in the future, but first we want to add 4K versions and RGB 4:4:4 versions.
Respectfully,
Paul Gale February 23rd, 2014 09:45 AM
Thanks Dan.
