Locking 2 or more Odyssey recorders together
Will it be possible to lock 2 or more Odyssey recorders together so that they have the same timecode?
My scenario: I have 2 EX3s and (soon) an FS700. I had in mind to get a 7Q with the FS700 option. I thought I would later add the quad recording option until I saw that it cost... a lot! It would actually be cheaper for me to purchase 2 additional Odyssey7s for use on the EX3 cameras than it would be to unlock the Quad record option. So my question remains.... can the timecodes be locked? Thank you. |
Re: Locking 2 or more Odyssey recorders together
Dear Nathan,
The proper technique is to ensure that all cameras have the same timecode values. The Sony EX3 has Timecode Input and Output Connectors which makes it possible to lock the timecode together in both cameras. The Sony FS700 does not seem to have Timecode Input and Output Connectors, which makes it hard to lock the timecode to the same value as another camera. There may be some tricks to get all three cameras to have the same timecode. Later, when we have our Multi-Stream recording option available (Q1, 2014), this becomes moot, as we will be able to accept multiple video streams and use the timecode value from the primary source (the first video input) for all recordings. I hope this helps. Respectfully, |
There maybe a way to lock the two Ex1s to the Fs700... The FS700 would have to be the master... |
Dear Friends,
If the application is for 3D, then for proper 3D, the cameras must be Genlocked (or even better Pixel Locked). What is the application? |
Hi Dan, etc.-
Thank you. This is helpful. My question was about multi-cam applications, not 3D. I think that what I had in mind here would work well. Thanks again. |
| All times are GMT -6. The time now is 04:52 PM. |
