-   Convergent Design Odyssey (https://www.dvinfo.net/forum/convergent-design-odyssey/)
-   -   FS700 triggers Nanoflash via SDI? (https://www.dvinfo.net/forum/convergent-design-odyssey/509800-fs700-triggers-nanoflash-via-sdi.html)
Al Yeung August 5th, 2012 11:04 AM
I know that the timecode over hdmi firmware for FS100 (and I assume FS700) is still pending, but can the FS700 over SDI trigger Nanoflash to start recording when you press one of the camera's "record" buttons? thank you.
Dan Keaton August 5th, 2012 05:03 PM
Re: FS700 triggers Nanoflash via SDI?
Dear Al,
The FS700 outputs timecode over HD-SDI.
If you use Record Run timecode, and choose System|Trigger|Timecode (TC), then the nanoFlash will start recording when the camera's timecode is rolling.
In addition, if we determine that the FS700 outputs a special signal over HD-SDI, the "Record Packet", then we will implement that in an upcoming firmware release.
